Opinions wanted
ratster
on Mapleshades brass footers? Was thinking about maybe trying them out on my CDP and speakers.Or,maybe not,depending on what you guys think.
Thanks and I will now go back to lurking :biggrin:
Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Post edited by ratster on
That all depends. Do you have a problem with vibrations ? What kind of rack do you have ? Glass is terrible for transfering vibrations, metal too. If your not on solid wood, the brass footers maybe a waste of coin and mapleshade footers sure aren't cheap. Plenty of other options out there for vibration control but given the right circumstances, heavy brass footers can make a difference. Are your speakers on carpet, over wood floor or concrete ? Just putting brass footers on a cdp that rests on glass or metal racks is a waste without first putting a solid piece of hardwood under.HT SYSTEM-
lsi 9's -
Floors are wood over concrete and vibrations aren't noticeable at my normal listening levels but crank it up a little and they are their but not terrible.
The CDP is on a particle board shelf.Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun -
Not all vibrations come from underneath, from the floor, in fact alot are airborne, and some chassis/cases of equipment are flimsy enough to be affected that way. heavy objects in stratejic places on the outer enclosure can help damp unwanted resoneces, you have to experiment. Just another thought to ponder.Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
