NAD c372 remote control
aloutah
I need a remote for a NAD c372 integrated amp. Does anyone here have one? Or know where i can get one? Thanks, I appreciate it.
Post edited by aloutah on
Used is preferrable, but if you know somewhere to get a new replacement that would work too.
bump
bump
Looks like you have options on eBay.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I couldnt find the replacement on ebay. Did you find one there, and if so, do you have a link? Thanks. -
You can most likely use some of those remotes. You have to call NAD and see which ones will run the same functions.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
The Nad SR5 remote was the original one that came with your amp. The Substitute remote is the SR8. You can get this remote from Remotes.com....although they are listing it at $52. If you look to E-Bay then you will know what Remote to look for. Either the SR5 or SR8. Others may work, and Nad customer service will be able to tell you this. Good luck.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Their is a Nad SR5 on E-bay right now " New In Box " listed from the United Kingdom. Opening Bid is aprox $19.68 U.S dollars. Shipping is very good also. Put in Nad Remote in the E-bay search engine and go to the bottem where the International section is. You may get this for a good price.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
