NAD c372 remote control
aloutah
aloutah Posts: 241
edited August 2011 in Wanted (WTB) Classifieds
I need a remote for a NAD c372 integrated amp. Does anyone here have one? Or know where i can get one? Thanks, I appreciate it.
Post edited by aloutah on
  • aloutah
    aloutah Posts: 241
    edited March 2011
    Used is preferrable, but if you know somewhere to get a new replacement that would work too.
  • aloutah
    aloutah Posts: 241
    edited March 2011
  • aloutah
    aloutah Posts: 241
    edited July 2011
  • dorokusai
    dorokusai Posts: 25,577
    edited July 2011
    Looks like you have options on eBay.
  • aloutah
    aloutah Posts: 241
    edited July 2011
    dorokusai wrote: »
    I couldnt find the replacement on ebay. Did you find one there, and if so, do you have a link? Thanks.
  • dorokusai
    edited July 2011
    You can most likely use some of those remotes. You have to call NAD and see which ones will run the same functions.
  • larry777
    larry777 Posts: 480
    edited August 2011
    The Nad SR5 remote was the original one that came with your amp. The Substitute remote is the SR8. You can get this remote from Remotes.com....although they are listing it at $52. If you look to E-Bay then you will know what Remote to look for. Either the SR5 or SR8. Others may work, and Nad customer service will be able to tell you this. Good luck.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • larry777
    larry777 Posts: 480
    edited August 2011
    Their is a Nad SR5 on E-bay right now " New In Box " listed from the United Kingdom. Opening Bid is aprox $19.68 U.S dollars. Shipping is very good also. Put in Nad Remote in the E-bay search engine and go to the bottem where the International section is. You may get this for a good price.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
