Looking for IC's for my 5ch amp
djperez81
I just bought a 5ch amp and been looking for IC's. not looking to spend a fortune on them though. I seen these on monoprice http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2682&seq=1&format=2
I figured i would buy 5 of them and that should be fine. And yes i need the length between 10-12 ft. Any other suggestions would be helpful. Thanks
Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix
-Jimi Hendrix
Post edited by djperez81 on
Signal cable.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
blue jeans cable is another alternative,somewhat cheaper..Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup -
I checked those both out but unfortunately i cant afford those. Do you think the ones from monoprice will work?Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Absolutely no harm in starting out with monoprice if thats what your budget will allow. I did that myself... There's a lot of good deals when you're ready to upgrade, both here and on audiogon among other places...Fronts: Wharfedale diamond 9.6
Thats probably gonna do order those from monoprice. i cant justify spending that much money on IC's IMO.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I have the monoprice ic's and they are super crap and the worst part of my rig .
DJ, MonoPrice is the right place, but there's no need to use unnecessarily thick and stiff RG6 at audio frequencies. Satellite TV in from the dish is a different matter. I 've used these in various lengths for several years and they do this very simple job as well as it can be done. Five of them at $1.67 each is all you need and they have the benefit of being thinner and more flexible.
Since you want to keep it within a certain budget DJ, Monoprice looks like your best bet. I'd go with John's suggestions. Good luck and let us know what you end up getting.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
10-12 ft for each IC ?
Is the amp going to be on the other side of the room ?HT SYSTEM-
lsi 9's -
Do you think 10-12 feet will cause some sort of problem? -
I'd pick Radio Shack, Belkin, or just about anything else over Monorprice. Besides sounding awful, they had a very tight grip which can damage equipment. The only other brand I found just as awful was AR(Acoustic Research)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No i just have a huge entertainment center and the only place the amp would fit is that far from the receiver. they are actually about 7 feet apart i just wanted eough slack to be able to pull the amp out so i guess 10ft should do. Thanks for the advice guys.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Seeing that the amp will be farther away, have you given any thought to the speaker cable that will also need to be that much further ? Just asking is all.HT SYSTEM-
lsi 9's -
All my speaker cables reached that was the first thing i checked. ThanksMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
I'd at least use these Belkin PureAV's, they're only $12 a pair with free shipping and 12' length. Im sure you can find em even cheaper if you shop around. I thought i'd take the cheap route for interconnects but didn't realize how much I was missing.
http://www.amazon.com/Belkin-PureAV-AV20300-12-12-Foot-Audio/dp/B0001VWJ8Y/ref=sr_1_21?ie=UTF8&qid=1311366895&sr=8-21 -
+1^^^^SDA-2BTL with custom IC
