The most amazing system tweak ever...
nooshinjohn
nooshinjohn Posts: 25,928
edited July 2011 in DIY, Mods & Tweaks
and it can likely be used to clean the tree sap off your car too!:rolleyes::biggrin:
http://cgi.audiogon.com/cgi-bin/cl.pl?accstwek&1316045832
Post edited by nooshinjohn on
  • fbm211
    fbm211 Posts: 1,488
    edited July 2011
    How about some candy cane spikes and 32oz cans of monster on top of the speakers. And some pretty nightGlow throw pillows inside the speakers to tighten up the bass.
    System???? Maybe some painted lava rocks.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • thetawave2
    thetawave2 Posts: 268
    edited July 2011
    This reduces my faith in audiogon a bit....
    My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
  • decal
    decal Posts: 3,205
    edited July 2011
    It has nothing to do with Audiogon, it's a product from Coconut-Audio (emphasis on nut!!!). BTW, there's plenty of nutty ideas here on your beloved CP.
  • deronb1
    deronb1 Posts: 5,021
    edited July 2011
    What the hell do you do with it?
  • drumminman
    drumminman Posts: 3,396
    edited July 2011
    deronb1 wrote: »
    Lots of threads on crystals on AA. I've used 'em :eek: and found amethyst quartz to make a noticeable, positive difference :wink:.
    When properly placed they removed a grunge from the system that I wasn't even aware I had. And they're cheap and easy to experiement with.
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    Pure snake oil!
    Frozen hockey pucks are where it's at and offer real performance advantages.Sceptical?Well I will gladly set you up with a weight matched pair for a mere $100 so you can hear it for yourself.:smile:
  • decal
    decal Posts: 3,205
    edited July 2011
    ^^^^^ Great deal ^^^^^
    If I wasn't cash strapped, I'd be all over that.:biggrin:
  • deronb1
    edited July 2011
    does it just sit in the cabinet?
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    decal wrote: »
    If you can't quite swing it now we do offer the "easy" payment plan of 5 x $20.:wink:
  • thetawave2
    edited July 2011
    decal wrote: »
    By "Audiogon" I mean "individuals within the Audiogon community"
  • decal
    decal Posts: 3,205
    edited July 2011
    FTGV wrote: »
    I was thinking more like 20 $5.00 notes!!!!!:biggrin:
  • drumminman
    edited July 2011
    FTGV wrote: »
    Pure snake oil!
    the stuff the Agon seller, Coconuts, is pushing or the concept of using crystals in general?
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited July 2011
    You hook these babys up with expensive cables, and wow
    humpty dumpty was pushed
    Tony M Posts: 11,624
    edited July 2011
    Isn't there a saying??.....
    Crazy as a coconut...:tongue:
  • ysss
    ysss Posts: 213
    edited July 2011
    This gives a whole new meaning to psychoacoustic.
    I truly believe these amulets can give new/positive aural experience to some people when they truly believe in them.
    They'll be able to hear it, although the difference can't be detected with measuring apparatus.
    Toolfan66 Posts: 18,067
    edited July 2011
    I put water bags in my speakers for the liquid effect, it helps with the roll off in the highs..
  • FTGV
    FTGV Posts: 3,650
    edited July 2011
    drumminman wrote: »
    Yes.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    thetawave2 wrote: »
    Audiogon is just the audio specific version of eBay....why is it their fault?
    EDIT: Theta - Just read your later reply. Understood. That community has started to change in the past couple years and it was only a matter of time.
  • evhudsons
    evhudsons Posts: 1,175
    edited July 2011
    I'm sure play-do or silly putty would have the same effect. Some chicken feathers and voodoo dolls would help a lot too. They soak up all the mechanical bad ju ju and send moonbeams of acoustical love right to the brain in need of alpha states. Beer is cheaper and easier to get, and doesn't freak out the ol' lady, kids or neighbors.
