The most amazing system tweak ever...
nooshinjohn
and it can likely be used to clean the tree sap off your car too!:rolleyes::biggrin:
http://cgi.audiogon.com/cgi-bin/cl.pl?accstwek&1316045832
Post edited by nooshinjohn on
How about some candy cane spikes and 32oz cans of monster on top of the speakers. And some pretty nightGlow throw pillows inside the speakers to tighten up the bass.
System???? Maybe some painted lava rocks.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
This reduces my faith in audiogon a bit....My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
It has nothing to do with Audiogon, it's a product from Coconut-Audio (emphasis on nut!!!). BTW, there's plenty of nutty ideas here on your beloved CP.If you can't hear a difference, don't waste your money.
What the hell do you do with it?
Lots of threads on crystals on AA. I've used 'em :eek: and found amethyst quartz to make a noticeable, positive difference
When properly placed they removed a grunge from the system that I wasn't even aware I had. And they're cheap and easy to experiement with."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Pure snake oil!
Frozen hockey pucks are where it's at and offer real performance advantages.Sceptical?Well I will gladly set you up with a weight matched pair for a mere $100 so you can hear it for yourself.
^^^^^ Great deal ^^^^^
If I wasn't cash strapped, I'd be all over that.:biggrin:If you can't hear a difference, don't waste your money. -
does it just sit in the cabinet?
If you can't quite swing it now we do offer the "easy" payment plan of 5 x $20.^^^^^ Great deal ^^^^^
By "Audiogon" I mean "individuals within the Audiogon community"My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers -
I was thinking more like 20 $5.00 notes!!!!!:biggrin:If you can't hear a difference, don't waste your money. -
Pure snake oil!
the stuff the Agon seller, Coconuts, is pushing or the concept of using crystals in general?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
You hook these babys up with expensive cables, and wowhumpty dumpty was pushed
Isn't there a saying??.....
Crazy as a coconut...
This gives a whole new meaning to psychoacoustic.
I truly believe these amulets can give new/positive aural experience to some people when they truly believe in them.
They'll be able to hear it, although the difference can't be detected with measuring apparatus. -
I put water bags in my speakers for the liquid effect, it helps with the roll off in the highs..
drumminman wrote: »the stuff the Agon seller, Coconuts, is pushing or the concept of using crystals in general?
Yes. -
thetawave2 wrote: »This reduces my faith in audiogon a bit....
Audiogon is just the audio specific version of eBay....why is it their fault?
EDIT: Theta - Just read your later reply. Understood. That community has started to change in the past couple years and it was only a matter of time.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I'm sure play-do or silly putty would have the same effect. Some chicken feathers and voodoo dolls would help a lot too. They soak up all the mechanical bad ju ju and send moonbeams of acoustical love right to the brain in need of alpha states. Beer is cheaper and easier to get, and doesn't freak out the ol' lady, kids or neighbors.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
