HP Laptop help
jim 249
jim 249 Posts: 347
edited November 2011 in The Clubhouse
I bought a used power supply for my daughters laptop computer. The old one quit working. The computer works fine with this supply. My question is, the old supply was rated at 18.5 vdc @ 90 watts, the new one is 19.0 vdc @ 135 watts. There must be a tolerance for input voltage for computers. Does any one see any harm from using this replacement supply? Thanks for any help!:eek:
Post edited by jim 249 on
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2011
    Should not be any harm to the computer. That power supply will work in charging the higher rated 9hr batteries, so you should be good.
    EndersShadow Posts: 17,705
    edited July 2011
    Sherardp wrote: »
    anonymouse wrote: »
    Agree
    AND.......Boom goes the dynamite......:eek:
    What they said :biggrin:
  • jim 249
    jim 249 Posts: 347
    edited July 2011
    Thanks for the advice!
  • TECHNOKID
    TECHNOKID Posts: 4,298
    :arrowu:First, reporting spammer above...:arrowu:
    No issue whatsoever as .5v will not make any difference (you have a voltage tolerance less than 10% and is NO issue). The greater power rating means the power supply will endure more current draw then the old one therefore this power supply will more likely last longer.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Glowrdr
    Glowrdr Posts: 1,103
    The reasoning for the change is so they can have the same power supply for laptops, and docks. (Also the newer 17" laptops need the extra juice). It was a cost thing, making everything a little better was cheaper than making 3 different ones just so they had a cheaper version.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
