HP Laptop help
jim 249
I bought a used power supply for my daughters laptop computer. The old one quit working. The computer works fine with this supply. My question is, the old supply was rated at 18.5 vdc @ 90 watts, the new one is 19.0 vdc @ 135 watts. There must be a tolerance for input voltage for computers. Does any one see any harm from using this replacement supply? Thanks for any help!:eek:
Post edited by jim 249 on
Should not be any harm to the computer. That power supply will work in charging the higher rated 9hr batteries, so you should be good.Shoot the jumper.....................BALLIN.............!!!!!
Should not be any harm to the computer. That power supply will work in charging the higher rated 9hr batteries, so you should be good.anonymouse wrote: »Agree
AND.......Boom goes the dynamite......:eek:
What they said :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks for the advice!
:arrowu:First, reporting spammer above...:arrowu:My question is, the old supply was rated at 18.5 vdc @ 90 watts, the new one is 19.0 vdc @ 135 watts. There must be a tolerance for input voltage for computers. Does any one see any harm from using this replacement supply?DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
The reasoning for the change is so they can have the same power supply for laptops, and docks. (Also the newer 17" laptops need the extra juice). It was a cost thing, making everything a little better was cheaper than making 3 different ones just so they had a cheaper version.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa"
