In wall - cut 1/4" too wide. Putty or Leave>
in-mn
in-mn Posts: 9
Its bothering me. I cut them exact to line, and they were too small. So I sat with a drywall rasp slowly whittling away, trying again, etc. Finally I got impatient. Did 1, didnt check to see how much i needed on other. Made other 1/4" too wide. so its no longer snug
its the rc85i, so 8" woofer. Fairly heavy.
Should I try some drywall putty, cardboard, etc, to help make it snug? or?
Or, just leave it?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited July 2011
    I think what you're saying the hole to place speaker in is 1/4" too large, but the speaker edge would cover it fine? If so you're fine, don't worry. IMHO.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
