In wall - cut 1/4" too wide. Putty or Leave>
in-mn
Its bothering me. I cut them exact to line, and they were too small. So I sat with a drywall rasp slowly whittling away, trying again, etc. Finally I got impatient. Did 1, didnt check to see how much i needed on other. Made other 1/4" too wide. so its no longer snug
its the rc85i, so 8" woofer. Fairly heavy.
Should I try some drywall putty, cardboard, etc, to help make it snug? or?
Or, just leave it?
Or, just leave it?
I think what you're saying the hole to place speaker in is 1/4" too large, but the speaker edge would cover it fine? If so you're fine, don't worry. IMHO.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
