Not receiving 1080p
doug lang
Just bought sammy 3-d 1080p tv, and I only can get 1080i. Can this be my processor Anthem or possibly my hdmi cables. Or is it not possible to receive. I am using dtv and they say their signal is 1080p. Thanks Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Isen`t normally all cable or satellit tv 720P being up-converted to 1080i ???? I have IPTV ( Bell Fibe ) and it is 720P up-converted to 1080i using component or HDMI .
Almost all of the HD stations are 720P or 1080i.
Only a few video on demand movies are 1080P. At least that is how it was when I had DirecTV. -
If you want good 1080P, watch a high quality Blu-ray movie. This is where you will get your best picture...
I would check the settings on your cable box and make sure (if Comcast) the box is selected to 1080i. If you are passing HDMI through the receiver, make sure your receiver settings are passing the correct setting. On mine you can change itSystem:
Sony Blue Ray - BDP-S380
Comcast DVR - DCX3400m
Onkyo AV receiver - TX-NR609
Sony LCD TV - KDL-46V4100
Speakers:
Center: VM10
Front Left: VM10
Front Right: VM10
Subwoofer: Cambridge SoundWorks BassCube 8s
Surrounds: TBD - working on updating since a living room redesign and new receiver addition
Extras:
1 CSi30
1 CS175i
2 RTi38
Pair of FXi30
Onkyo TX-SR600 -
Who is "they" and why are they lieing to you ?
Most do not broadcast in 1080p, only a few on demand movies and maybe a select few sports channels from what I gather. Run a bluray disc and see if your receiver recognizes the 1080p signal so you know it's not the receiver. Also, you may have to check the settings on the input you have the cable box plugged into on the receiver and the cable box itself.HT SYSTEM-
lsi 9's -
With my blue ray I get 1080p. Called back dtv and they told me only p/p views only get 1080p.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
My goodness, you put up the same question at the other thread, the answer was provided, and you still asked for the same thing again?
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
My Comcast (xfinity) has gone to hell since Xfinity has taken over. All HD channels look like crap.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I'm with TNR.. Broadcast 1080p...in your dreams! Where do you guys live? Cupertino...next to Apple? lol
Just happen three days ago.Thin black line horiconally about 1/3 up from bottom..Samsung 50" plasma its 31 months old..get it fix? or replace?Testing
Testing
Testing -
So what does it have to do with this thread? :biggrin:Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
