PSW505 - should I upgrade?
matchan
matchan Posts: 73
edited July 2011 in Speakers
So far happy with the PSW 505. However, will I see a MAJOR difference if I move to Hsu VTF 3 MK 3 or SVS PB 12 NSD ?
All are 12".
Application is almost 100% HT
Post edited by matchan on
    edited June 2011
    The PSW505 is a good sub for 250 or less new but it's not in the same league as the SVS or the HSU.
    However...don't be too quick to upgrade unless you have the cash on hand because you'll go bankrupt pretty quickly.
    I'd also suggest you look at the Epik Legend in a similar price range!
    Proceed wisely!
    cnh
  • Brunt
    Brunt Posts: 20
    edited June 2011
    Just sold my PSW505 and I am ordering a custom sub from Elemental DEsigns...Around here not so much, but on other forums and by reading reviews, it seems like the 2 subs you mentioned should walk all over the Polk. I liked mine and for the $ it was a steal as my first sub, but after hearing a better quality sub, I started to hear it's limitations. Again, $220 shipped for the 505 gave me no regrets, but once I heard a
    $600+ sub I knew I wanted a bit more.
    For me it came down to this, I don't need to blow my foundation out, but I never want a sub that won't play certain frequencies. If I buy a sub with my own money, I never want it to make a strange noise or something during certain scenes...like WoTW or The Hulk's sonic gun scene.
    tonyb Posts: 33,072
    edited June 2011
    matchan wrote: »
    All are 12".
    in short......yes you will.
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    Don`t get 1 .... get 2 of them and go nuts :biggrin:
  • wkdwarrior98
    wkdwarrior98 Posts: 49
    edited June 2011
    H/T Set-up
    Sony Bravia 55" LCD
    Onkyo TX-SR608
    Polk Audio Monitor 60's (fronts)
    Polk Audio Monitor 40's (surrounds)
    Polk Audio CS2 (center)
    Polk Audio PSW505 (subwoofer)
    Zone 2
    Polk Audio Atrium 25
    (perfect speakers by the pool)
  • B Run
    B Run Posts: 1,888
    edited June 2011
    I tried that when I got tired of my 505, I ended up with dual 505's that I got tired of pretty quickly after that. I went to an SVS and realized what i'd been missing.
  • matchan
    matchan Posts: 73
    edited June 2011
    Hi B Run,
    You have an NR-3008 and you still needed external amplification to run the RTi8's? Is that not a bit of overkill ? Did you notice a difference in SQ ?
    Specifically what was your take on 505 to SVS ? Why did you choose a cylindrical sub instead of the PB-12/PB-13 etc
  • B Run
    B Run Posts: 1,888
    edited June 2011
    Honestly I got my 3008 in about a week ago and haven't hooked my Adcom back up yet. I'm debating selling it or holding onto it in case I ever go with Lsi's. The 3008 is more than enough for the Rti8's.
    I have a pretty large theater room and was running dual 505's. They did a good job filling the room, but they tended to be a little slow and muddy on the bottom end. I did an even trade for an SVS, I went cylindrical because it was on craigslist for cheap as hell:biggrin:. The SVS showed me what LOW bass sounded like, and could actually pressurize my room better than both 505's. It's very clean and fast, and sounds good with music and well as HT.
  • matchan
    matchan Posts: 73
    edited June 2011
    what was your AVR before the 3008 ? What difference do you see with the 3008 ?
  • B Run
    B Run Posts: 1,888
    edited June 2011
    I've been through way too many AVR's this year. I had a Denon 1909, Yamaha RXV1800 and then Pioneer VSX1120 before I got my Adcom amp. I ran the Pioneer with the Adcom for a while and really liked the sound. I'm always wanting to upgrade and try something new, so I bought a Marantz 6005 to use as a pre/pro, but it lasted about 20 minutes and quit outputting video. I returned it for the Harman Kardon 3600 which I tried so hard to like but absolutely hated. The ezset/eq was crap, it sounded terrible and had a few quirks I couldn't live with. I finally bought the Onkyo 3008 last week. I notice after running the Audyssey multeq xt32 it was the best my system has ever sounded. It was perfectly calibrated, my sub finally sounded the way I wanted, and I noticed a lot more detail and clarity. It is slightly brighter than some other ones i'd tried, but still has plenty of punch and bottom end on it. I haven't even bothered to hook my amp back up, I figured if I really didn't feel like the Onkyo was enough i'd keep it but i'll prob sell it here pretty soon.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited June 2011
    does anyone on here have or have listened to the svs nds12 or whatever it is. I'm VERY tempted to try it!
    Just got that un-scratchable itch... you know
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
