Does this have enough juice ?
matchan
matchan Posts: 73
edited July 2011 in Electronics
I have an Onkyo 606 that puts out 90 watts/channel. If I get an RTI A7 (20-300 wpc), will my receiver do justice ?
For optimal listening, what kind of power do I need ? 120wpc or more ? Please share your thoughts
Post edited by matchan on
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    matchan wrote: »
    Speakers like the A7 like very much of clean power :biggrin: meaning that you should and it will help you to considered a receiver with pre-outs . If you like Onkyo check this Onkyo HT-RC180 , the good thing is that they are authorized seller by Onkyo , the bad is that they don`t ship to canada :mad:
    edited June 2011
    +1,
    Get an Onkyo 70X series with pre-outs and a used power amp of 200 watts X 2 for the A7s--you'll thank us later!
    That RC180 is selling for a terrific price...basically a HT in a box version of an 80X series--I think?
    You'll still need a power amp, though!
    cnh
  • MADGSF
    MADGSF Posts: 603
    edited June 2011
    At low volumes your current AVR will be fine. If you want to crank it to 11 then you will need quality amplification. IMO quality is more important than quantity when it comes to watts. I would get a quality amp with 120watts/channel over a not-quality amp with 300 watts/channel.
    Some amps to consider are B&K, Rotel, Parasound, Adcom, NAD or Proceed and many others I did not mention. Don't be afraid to go used as your dollar will go much farther. I have a B&K and am happy with it.
    One other option to consider is to get speakers that are easier to drive such as the RTiA5 and a good sub instead of the A7.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • matchan
    matchan Posts: 73
    edited June 2011
    I am looking for the best possible audio experience. Will an Onkyo 809 (135 wpc) give me stellar sound with the A7/9 or do I need to pair the 809 to something like emotiva xpc-3 ?
    Or how about Yamaha A2000 ? (130wpc)
    tonyb Posts: 33,070
    edited June 2011
    matchan wrote: »
    In surround mode, it drops to 80 watts I believe. Anyway, every speaker benefits from quality power, which most avr's seem to lack. Yes you can run them off that avr, will they sound their best ?....no, but they will work for you.
  • matchan
    matchan Posts: 73
    edited June 2011
    tonyb wrote: »
    What if I bi-amp the fronts ?
    tonyb Posts: 33,070
    edited June 2011
    matchan wrote: »
    We probably get that question 10 times a week since the marketing guru's decided to use that phrase.
    Using a receiver for biamping is not bi amping, period, forget that marketing junk they shove at you. Your still using the same power supply no matter how you dice it.
    You can run those speakers from the 606, you just won't get everything out of them that they can do. My advice is to stay on the lower end of the rti series, or if you go bigger to keep the volume down while you save up for a newer receiver with preouts to add an amp.
    Good luck to you, and let us know what you wind up with.
  • matchan
    matchan Posts: 73
    edited June 2011
    so even if i sacrifice 2 channels in my 7.1 to "biamp" the fronts, i really wont see much gain ?
  • Almadacr
    Almadacr Posts: 185
    edited June 2011
    matchan wrote: »
    A emo XPA-3 will give you 200 watts at 8 ohm all channels driven , tell me what you think ????
    tonyb Posts: 33,070
    edited June 2011
    matchan wrote: »
    nope....it's not biamping anything.
  • matchan
    matchan Posts: 73
    edited June 2011
    i cant quiet believe it - biamping is a farce ?? :confused::confused::confused:
    So in theory, If I get a receiver like NR-809 or NR-3008 with 140wpc, then I am getting an increase of 50 wpc over the NR-606 which puts out 90wpc.
    From what I understand,to double volume I need 10 times more amplification. With a 50% increase(90 to 140), how does it benefit the RTI a7/9 etc to put out louder/cleaner sound etc ?
    If all receivers cant output the rated watts in full surround mode (thus the need for a power amp) , then do all of you with full range speakers use external amplification ?
  • adabro
    adabro Posts: 212
    edited June 2011
    As a reference for you matchan - I initially paired my A9's with the Onkyo 807 (also with the CSi A6 center, Monitor 40 surrounds and a powered sub).
    I added an XPA-3 after a few months and did not really hear any difference. I've had the setup for about a year and a half now, maybe I would notice if I took the amp away, but I can't say it made a big change.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2011
    Welcome to Club Polk Match.
    Receiver companies give out misleading statements as far as power goes. The truth is is that very very few will drive speakers to their full potential. This is why we always suggest that newbies get receivers that have preouts for separate amplification down the line. The more speakers you add the less power goes to each speaker.
    More power allows the speakers to operate to their full potential no matter what the volume is. It's not just about loudness, it's about hearing all the details that are on the recording. Receivers don't have that power to give, so you don't hear those finer details.
    Biamping off of a receiver is a waste of time since all you are doing is trying to get more power out of an already stressed amp within the receiver.
    Get a reciever that has all the bells & whistles that you want it to have & then get a 5-7 channel 200wcp amp either new or used, and you can be done with this particular upgrade since you can use the amp throughout all other upgrades to your system.
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2011
    When it comes to power, ask yourself 3 questions:
    1. How big is the area
    2. How efficient are my speakers
    3. How loud do I want to listen
    Then consider, every 3dB's of increase in sound pressure level requires doubling of the wattage. Here's an example of a speaker with an efficiency of 89dB @ 1 watt/1 meter:
    dB SPL
    Watts Needed
    89dB
    1 watt
    92dB
    2 watts
    95dB
    4 watts
    98dB
    8 watts
    101dB
    16 watts
    104dB
    32 watts
    107dB
    64 watts
    110dB
    128 watts
    113dB
    256 watts
    You get the idea...
  • Jer.War
    Jer.War Posts: 180
    edited June 2011
    When I first purchased my LSI15's I was running them off of a Yamaha-RXV1700 reciever. The speakes sounded pretty flat and the bass has no punch. My Yahama allowed me to try bi-amping, so I did. I definately noticed a difference. It is not about loudness as it is about current. Speakers are an inductive load which require current to move the cone in and out. My yamaha has a discrete amplfier circuit for all 7 channels. The way I understood what I heard was that I was able to supply a bit more current to the speakers. Also the H.F and L.F drivers were now supplied by two different amplifier (current sources) circuits. Bottom line is it worked. However, past moderate volumes you could hear the limitations of using a receiver in this fashion. Bass would get sloppy, and sound was no longer balanced between the H.F and L.F drivers.
    However, now that I had the money and oppurtunity to purchase a used B&K Ref200.2 the difference pretty substantial. Bass is tight and punchy, improved soundstage, much more balanced frequency response no matter what the volume
    All recievers are not built the same, but if you purchase one w/ pre-outs you should be in good shape to upgrade in the future. Rome wasn't built in a day afterall...
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • steveinaz
    edited June 2011
    Bass notes require a lot of power, this is where high current amp designs shine.
  • matchan
    matchan Posts: 73
    edited June 2011
    thanks all. I am planning to get an RTI A7 or A9 and upgrade my receiver (an Onkyo 606) to either a Onkyo NR 809/1008/3008. Each with about 135-140wpc.
    The 3008 is a high current amp.
    Will the 809/1008/3008 sufficiently drive the A7/A9.
    Specifically will the 3008 drive better than 809 ?
    Room is 20x10x10. Dedicated HT room. Sound treated.
    For HT , I currently cannot listen at over 40 out of 70 (606 does not have reference level volume indicators).
    So I am not necessarily looking for LOUDER, just CLEANER, BETTER, QUALITY.
    For 2 ch music via ipod, I can crank it to 60 or so before I start to feel its really loud..
  • niente
    niente Posts: 68
    edited July 2011
    if this is the bottom line for you - follow above posts- pre outs and separate Amp
    why spend more for recvr power you wont use - 809 and amp
    good luck
    Onkyo TX-SR804 receiver
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
    Monster AC line cond
    Audioquest, Blue Jeans & Monster wires/connects
    40" Sony Bravia XBR6
    tonyb Posts: 33,070
    edited July 2011
    Adding an amp will definately get you cleaner, better quality,although that 3008 is plenty to drive those speaks. It's nice to have an amp for when you move up the speaker food chain and start getting into 4 ohm loads. Your call, you could swing either way.
  • rebuy
    rebuy Posts: 695
    edited July 2011
    I don't think he's listening. I think he wants to run the speakers off a AVR, period. He keeps talking about running the system through the AVR with a Bigger AVR.
    What kind of speakers do you have now?
    If you're so concerned about the larger speakers, Why not go ahead and buy them and hook them up to your existing equipment and see if you like the way they sound. If you are unhappy about the way they sound after you buy them, then buy a bigger power supply.
    It seems like a lot of people worry about the watts the speaker can handle.
    You'll blow them faster from low power than high power.
    I know you are talking about high power and high current and all Onkyo are considered high current amps, so the 606 you have is already high current.
    You might not drive the receiver to clipping if you have more than 100 watts
    of high current power. You'd be surprised at the way power is delivered from an amp to make a decent sound pressure in a given room. You'd need a power meter to understand and see for yourself what I'm talking about.
    When taking about separates for large speakers like you want to buy, wattage is not the only factor, others factors are current and Dynamic Headroom. Polk builds a quality product despite the Chinese Connection.
    If I was running large Polks, current and headroom would be more of a focus for me rather than watts alone.
  • matchan
    matchan Posts: 73
    edited July 2011
    Thanks all. The idea is to buy the best AVR I can afford as I know the 606 wont cut it.
    The dilema comes to these 2 options
    Best AVR I can afford today + Consider Amp in the future
    Go Separates right now , Get a lower end receiver + Get Amp now!
    Many people in this forum have reported not nearing a big difference with the RTI a7 and power amps (over Onkyo 809/3008).
    Just want my dollar to go far...
  • cfrizz
    edited July 2011
    I don't know what many people you are referring to, since they didn't post in this thread.
    Just about all of us have told you what you need to do to get the best sound from any speakers you might purchase now & in the future with plenty of good external amplification.
    If you don't want to believe/listen to it that's fine, it's your money & system.
  • matchan
    matchan Posts: 73
    edited July 2011
    Let me ask a specific question:
    As far as the differences in amplification between the 809 and 3008 , the only significant difference is the high current feature of the 3008. If the watts are similar/same then is it fair to say that both amps will drive the RTI a7 the same in terms of quality ?
    tonyb Posts: 33,070
    edited July 2011
    matchan wrote: »
    ........and isn't current what makes most any speaker perform it's best ? You answered your own question my man.
    Actually, it comes down to wanting great sound from a limited wallet, and thats cool,we all have our limits. You could go either way on the receiver,each on their own will drive the 7's fine. The 3008 will do it just a tad better though. You could always add an amp later when your wallet lets you if you go with a cheaper receiver,just make sure it has the preouts.
  • PrazVT
    PrazVT Posts: 1,607
    edited July 2011
    and FYI, even w/ a '125wpc' Denon 3311ci, my RTI A7s never sounded as good as when I got an outboard amp. Initially, adding a 250w x 2 (45 amp peak) amp introduced actual bass and soundstage to my music - I think my thread is still here from last year. 'Holy hell' was my reaction I think. Then upgrading to a 250w x 2 (60 amp peak) amp this year increased dynamics significantly and warmed up the high end a bit - so another incremental increase.
    But as tonyb said ..you can always add an amp later, when budget permits. Just know that there is room for improvement.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
