CS400i - what tool to remove faceplate?
fitness1
I just picked up a CS400i and it appears the tweeter is gone. I wanted to troubleshoot and make sure it's not the crossover before I replace the tweeter, but I cant figure out what I'm supposed to use to get access to the speakers.......not a flat head, phillips or hex head.....what is it??
Post edited by fitness1 on
Torx.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
thanks......and it begs the question: why the heck did they do that?? I'm relatively handy, but I don't have a set of Torx keys, never had the need until now.
I guess I should also ask what size? So I don't end up buying the wrong thing.
rjasonsteve reported5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
You can get a whole set of torx bits at home depot for $5-$6. Not the highest quality, but good for light work like this. -
and they are SAE, not metric right (I guess that's what I was getting at)
Torx have their own standard, T-1, T-2, T-3, etc. There are not really metric or sae sizes.
