CS400i - what tool to remove faceplate?
fitness1
I just picked up a CS400i and it appears the tweeter is gone. I wanted to troubleshoot and make sure it's not the crossover before I replace the tweeter, but I cant figure out what I'm supposed to use to get access to the speakers.......not a flat head, phillips or hex head.....what is it??
Torx.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
thanks......and it begs the question: why the heck did they do that?? I'm relatively handy, but I don't have a set of Torx keys, never had the need until now.
I guess I should also ask what size? So I don't end up buying the wrong thing.
rjasonsteve reported5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
You can get a whole set of torx bits at home depot for $5-$6. Not the highest quality, but good for light work like this. -
and they are SAE, not metric right (I guess that's what I was getting at)
Torx have their own standard, T-1, T-2, T-3, etc. There are not really metric or sae sizes.
