CS400i - what tool to remove faceplate?
fitness1
fitness1 Posts: 16
I just picked up a CS400i and it appears the tweeter is gone. I wanted to troubleshoot and make sure it's not the crossover before I replace the tweeter, but I cant figure out what I'm supposed to use to get access to the speakers.......not a flat head, phillips or hex head.....what is it??
Post edited by fitness1 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2011
    Torx.
  • fitness1
    fitness1 Posts: 16
    edited June 2011
    thanks......and it begs the question: why the heck did they do that?? I'm relatively handy, but I don't have a set of Torx keys, never had the need until now.
  • fitness1
    fitness1 Posts: 16
    edited June 2011
    I guess I should also ask what size? So I don't end up buying the wrong thing.:smile:
  • jimbo1421
    jimbo1421 Posts: 772
    edited June 2011
    rjasonsteve reported
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • WilliamM2
    WilliamM2 Posts: 4,809
    edited June 2011
    fitness1 wrote: »
    You can get a whole set of torx bits at home depot for $5-$6. Not the highest quality, but good for light work like this.
  • fitness1
    fitness1 Posts: 16
    edited June 2011
    and they are SAE, not metric right (I guess that's what I was getting at)
  • WilliamM2
    edited June 2011
    Torx have their own standard, T-1, T-2, T-3, etc. There are not really metric or sae sizes.
