Looking for Mono Blocks to power LSi15s
acmf74
acmf74 Posts: 937
edited June 2011 in Electronics
I got the itch and want to try the Mono Block route and have a pair of LSi15s that I want to power. My system is used both for HT and 2 channel listening. Can anyone recommend me a make and model?
I want to spend around 1200. Thanks!
Post edited by acmf74 on
  • carwashguy
    carwashguy Posts: 131
    edited June 2011
    I am using a pair of Wyred 4 Sound SX-1000. Absolutely love what they do for my LSi 15's. Bit more than you are looking to spend, but you may want to check out their website and take a look.
    Living Room
    LSi 15
    LSi7
    LSiC
    LSiFX
    2 EPIK Empire
    2 W4S Sx-1000
    Monster HTPS 7000 MKII
    Parasound 5250
    Onkyo PR-SC5508
    Oppo BDP-95
    Pro-Ject RM 1.3
    LG 55 LED
    Bedroom
    RTi A7
    CSi A6
    FXi A6
    2 PSW 125
    Onkyo TX-NR1008
    Panasonic 60 Plasma
  • Face
    Face Posts: 14,340
    edited June 2011
    Even their stereo amps are dual mono, for $1200 he should have no trouble finding a used ST-500.
    http://www.wyred4sound.com/webapps/category/74030/117839/17872
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2011
    +1 with the ST500 if you can swing it.
  • mantis
    mantis Posts: 17,373
    edited June 2011
    For $899.00 per mono , thats a killer deal if they perform like the spec's suggest they would. I'd like to try a et of these out myself.
    Dan
  • DMara
    DMara Posts: 1,434
    edited June 2011
    Don't hesitate to go with W4S amps. My ST-1000 is just too perfect for my LSi15 speakers; pairing it with the W4S DAC-2 produced such a warm tone and very smooth high end. I got it through a great Audiogon deal, and I'm kinda lucky it also included the Kimber Kable silver wiring throughout & WBT bindings upgrade even though the seller did not list it that way :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
    heiney9 Posts: 25,432
    edited June 2011
    Monarchy SM70 Pro
  • matchan
    matchan Posts: 73
    edited June 2011
    How does emotiva xpa 1 compare?
  • Face
    Face Posts: 14,340
    edited June 2011
    I wouldn't.
    edited June 2011
    matchan wrote: »
    Budget, entry level, it doesn't.
    If you must, try them both and see how they sound to you with your ears, in your rig with your music.
  • zingo
    zingo Posts: 11,258
    edited June 2011
    ICEpower based amplifiers are great with LSi speakers and highly recommended!
  • Face
    Face Posts: 14,340
    edited June 2011
    Still looking for an amp, I may have something in your price range, and I'm local.
