Cables question
anilksharma
Probably this is the best place to post this question...
What would be the decent cables 14gauge - 100ft for satellite Polk TL350 and subwoofer PSW505. I am browsing on internet and find variety of them available. Does the expensive cables provide better performance as well?
Dont have sub pre-out on the receiver.
Hardware store 12 gauge stranded twisted copper is more than enough for the gear, and length of run.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
CANARE 4S11 would be a great wire for them.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
There are very reasonable prices on two sites online 1. Partsexpress 2.Monoprice google to go there cuz I don't have the links stored.
thanks guys!
I went the monoprice route. I was not happy with the banana plugs, they didnt fit tight and was not happy. I then looked at the higher price stuff, blue jean ,mit and other. too expensive. i dont need high price wire. Then i found Terminated Speaker Cables at Audioholics and love them. Looks good, plugs fit real tight and the price was pretty good. I recommend the speaker cables .
http://store.audioholics.com/section/66265/1/terminated-speaker-cablesMarantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
I thought A'holics use galvanized fence wire??
:biggrin: -
Not unless it's cryo'ed !!!!!!!!!!!!!!!!:eek:
If you can't hear a difference, don't waste your money. -
I will second the CANARE 4S11.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems
