Cables question
anilksharma
anilksharma Posts: 34
Probably this is the best place to post this question...
What would be the decent cables 14gauge - 100ft for satellite Polk TL350 and subwoofer PSW505. I am browsing on internet and find variety of them available. Does the expensive cables provide better performance as well?
Post edited by anilksharma on
  • anilksharma
    edited June 2011
    Dont have sub pre-out on the receiver.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2011
    Hardware store 12 gauge stranded twisted copper is more than enough for the gear, and length of run.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited June 2011
    CANARE 4S11 would be a great wire for them.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • gdb
    gdb Posts: 6,012
    edited June 2011
    There are very reasonable prices on two sites online 1. Partsexpress 2.Monoprice google to go there cuz I don't have the links stored.:wink:
  • decal
    decal Posts: 3,205
    edited June 2011
    ^^^^^^reported^^^^^^
  • anilksharma
    edited June 2011
  • zingo
    zingo Posts: 11,258
    edited June 2011
    12AWG speaker cable from monoprice.
  • over50
    over50 Posts: 201
    edited June 2011
    I went the monoprice route. I was not happy with the banana plugs, they didnt fit tight and was not happy. I then looked at the higher price stuff, blue jean ,mit and other. too expensive. i dont need high price wire. Then i found Terminated Speaker Cables at Audioholics and love them. Looks good, plugs fit real tight and the price was pretty good. I recommend the speaker cables .
    http://store.audioholics.com/section/66265/1/terminated-speaker-cables
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • gdb
    gdb Posts: 6,012
    edited June 2011
    I thought A'holics use galvanized fence wire??:confused:
    :biggrin:
  • decal
    decal Posts: 3,205
    edited June 2011
    Not unless it's cryo'ed !!!!!!!!!!!!!!!!:eek::wink:
  • Obsession18
    Obsession18 Posts: 191
    edited June 2011
    I will second the CANARE 4S11.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
