Does this look right to you guys?
VR3
VR3 Posts: 29,496
edited June 2011 in DIY, Mods & Tweaks
I have successfully wired up one of these subs as the wiring came undone after all these years...
I only had one wire I could not be sure of since it was disconnected on both subs --
It is the white inductor - the lead connected to the red wire currently. It is the only wire I saw that had an indention where a wire had been...
Thoughts?
I also sent Ty a message but I really wanted to get these wired back up tonight. I had no idea both subs did not work
Post edited by VR3 on
    VR3 Posts: 29,496
    edited June 2011
    It puts out 5.5 ohms - but there are 4 8 ohm woofers?
    VR3 Posts: 29,496
    edited June 2011
    Just doing a quick trace --
    Bottom terminal + to large iron core inductor to positive speaker terminals and capacitor to ground
    Top terminals has wires that go to the top terminals above for tweeter bypass wiring
    The second set of wires from the top terminal is as follows...
    Positive to cap to inductor and positive wire (that goes to the terminals up top that lead to the midbass) to ground.
    Shooting for worse schematic drawing ever here --
    VR3 Posts: 29,496
    edited June 2011
    I think it is wired up right - it makes bass... but it immediately sends me receiver into protect mode... and I mean as soon as it hits higher volumes. Which is odd. But it is below the ohm load and power the receiver can put out
  • Face
    Face Posts: 14,340
    edited June 2011
    A 8ohm woofer can have a DCR under 6ohms. Crossover components in the circuit can also affect the DCR. As for the rest of your wiring, I'm too buzzed to examine it at the moment. :biggrin:
    VR3 Posts: 29,496
    edited June 2011
    Ah cmon Mike!
    PLEASE! :)
    I REALLY want these done tonight! I have soooo much to do! Damn trades! These are wired way different than my Taylod
    VR3 Posts: 29,496
    edited June 2011
    NVM!
    Ty is pulling a late nighter and confirmed my wiring
    Sweetness
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited June 2011
    Face wrote: »
    One of the best I have heard in a while. :)
