If you had $2000 for a tube integrated what would you get
JimBRICK
As the title says, I'm looking for a tube integrated amp around the $2000 taxes in range.
Going to be used with a set of klipsch corwalls and a Jolida tube cd player.
Later in the year I will also be adding a turntable.
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
Jim
Maybe check some of Grant Fidelty's offerings? Prima Luna from Upscale audio maybe?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Manley Stingray w/remote"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Thats listing for 6000 bucks2 CHANNEL
Under construction -
Do you want integrated phono in the amp, or will you be using a separate phono stage?
I was looking at this
http://www.rogueaudio.com/Products_Titan.htm
90WPC Magnum $2,195
90 WPC
- Remote volume control included
- 20Hz-30Khz bandwidth
- EL-34 output tubes, (3) 12AU7,
(2)12AX7 small signal tubes
- Phono section gain 35dB (before preamp)
- (3) line level inputs, (1) phono input
- (1) variable output, (1) fixed output
- Headphone amplifier
- 4 and 8 ohm taps
- Optional cover ($125)
- 18” W X 17.5” D X 5.5” H
- 50 lbs (55lbs shipping weight)2 CHANNEL
Oops, I guess that slipped my mind. So you're looking for NEW
its not a neccessity cause I can get one when I purchase my turntable. But it doesnt hurt2 CHANNEL
These get good reviews.
http://www.audiogon.com/cgi-bin/cls.pl?intatube&1312612888&/Audio-Space-Galaxy-34-tube
http://www.audiogon.com/cgi-bin/cls.pl?intatube&1312606617&/Cayin-A-100T
http://www.audiogon.com/cgi-bin/cls.pl?intatube&1312335653&/Rogue-Tempest-3"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I likey the cayin. Very sharp2 CHANNEL
Heiney wasn't too far off with the Stingray....at the old prices. Actually, it was the first thing that popped into my mind when I saw the thread. Check the used price the last one went for on the forum...:eek:
http://www.polkaudio.com/forums/showthread.php?t=73338&~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
The Audio Space Galaxy (the first link) gets stellar reviews. The only thing I don't like about it is if you are going to use NOS tubes (which I highly recommend) it will cost you an arm and a leg to re-tube.
If I were in the market, that's the one I'd be leaning towards if I had the coin to re-tube. Many of the tubes it takes I already have in my stash so the outlay wouldn't be too bad.
The Rogue stuff is very nice as well.
Used Stingray."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
1200 bucks wth damn2 CHANNEL
I was think about the Jolida JD1000RC . Very nice looking, Anyone spent some time with one? Oh and I'll buy that Manley off anyone for 1200 right now
2 CHANNEL
You need to consider, auto-bias, fixed bias or manual bias. I prefer manual with auto being a close second. Not a fan of fixed bias tube amps.
I wish I never had sold my onix sp3. Worst audio decision I ever made2 CHANNEL
Grant Fidelity is offering a new 40wpc, KT88 based PP integrated called the W30GT which has an integrated 12AX7 phono stage, as well as an integrated 24/192 DAC section. Initial reviews are good, and even Klipsch people like the sound even though it is push-pull. It looks like a great all-in-one solution.
Yeah, Manley about doubled their prices on everything in the lineup a couple of months back, IIRC. Not sure how that affected the used prices though. Great piece if you can find one.1200 bucks wth damn~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Very hard to find. I wish i bought Ted's! I could sell it for $4500 today
Real classy."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
According to the Agon Blue Book, it doesn't appear to have affected the prices of the original Stingray. If anything, the resale of the original has declined slightly since the debut of the Stingray II."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Rogue Audio Tempest II MagnumIf you can't hear a difference, don't waste your money.
Oh, I didn't realize they introduced another Stingray. Any difference between the two that you know of?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
CayinDKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
They added a remote and made it look not nearly as sexy: http://www.manleylabs.com/containerpages/stingray2.html"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Try getting hold of one... The thing about manley is that even though they were not cheap before the price raise, they offered more than the price would suggest.Vinyl, the final frontier...
I wondered about that. Sold mine as well. So far no regrets.
cubdogShuguang Classic S8MK
Emotiva XDA-2
Bel Canto M300 mono blocks
Bel Canto DAC 1.5
Squeezebox Touch
Sony SS-M7
A/D/S L710 -
90WPC Magnum $2,195
90 WPC
- 4 and 8 ohm taps
- 18? W X 17.5? D X 5.5? H
I would highly recommend this amp,it is something special,at least to my ears. -
aside from the usual suspects,,Rogue,Manley,,and given the efficiency of your speakers,,have you thought about any of the 2A3 or 300B offerings?JC approves....he told me so. (F-1 nut)
