If you had $2000 for a tube integrated what would you get
JimBRICK
JimBRICK Posts: 1,543
edited June 2011 in 2 Channel Audio
As the title says, I'm looking for a tube integrated amp around the $2000 taxes in range.
Going to be used with a set of klipsch corwalls and a Jolida tube cd player.
Later in the year I will also be adding a turntable.
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2011
    Jim
    Maybe check some of Grant Fidelty's offerings? Prima Luna from Upscale audio maybe?
    heiney9 Posts: 25,510
    edited June 2011
    Manley Stingray w/remote
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2011
    heiney9 wrote: »
    What he said.^^^
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • JimBRICK
    edited June 2011
    Thats listing for 6000 bucks
    2 CHANNEL
    Under construction
  • zingo
    zingo Posts: 11,258
    edited June 2011
    Do you want integrated phono in the amp, or will you be using a separate phono stage?
  • JimBRICK
    edited June 2011
    I was looking at this
    http://www.rogueaudio.com/Products_Titan.htm
    90WPC Magnum $2,195
    90 WPC
    - Remote volume control included
    - 20Hz-30Khz bandwidth
    - EL-34 output tubes, (3) 12AU7,
    (2)12AX7 small signal tubes
    - Phono section gain 35dB (before preamp)
    - (3) line level inputs, (1) phono input
    - (1) variable output, (1) fixed output
    - Headphone amplifier
    - 4 and 8 ohm taps
    - Optional cover ($125)
    - 18” W X 17.5” D X 5.5” H
    - 50 lbs (55lbs shipping weight)
    2 CHANNEL
    Under construction
    edited June 2011
    JimBRICK wrote: »
    Oops, I guess that slipped my mind. So you're looking for NEW
  • JimBRICK
    edited June 2011
    zingo wrote: »
    its not a neccessity cause I can get one when I purchase my turntable. But it doesnt hurt
    2 CHANNEL
    Under construction
    edited June 2011
  • steveinaz
    edited June 2011
  • JimBRICK
    edited June 2011
    I likey the cayin. Very sharp
    2 CHANNEL
    Under construction
    treitz3 Posts: 20,121
    edited June 2011
    Heiney wasn't too far off with the Stingray....at the old prices. Actually, it was the first thing that popped into my mind when I saw the thread. Check the used price the last one went for on the forum...:eek:
    http://www.polkaudio.com/forums/showthread.php?t=73338&
    edited June 2011
    The Audio Space Galaxy (the first link) gets stellar reviews. The only thing I don't like about it is if you are going to use NOS tubes (which I highly recommend) it will cost you an arm and a leg to re-tube.
    If I were in the market, that's the one I'd be leaning towards if I had the coin to re-tube. Many of the tubes it takes I already have in my stash so the outlay wouldn't be too bad.
    The Rogue stuff is very nice as well.
  • Face
    Face Posts: 14,340
    edited June 2011
    Used Stingray.
  • JimBRICK
    edited June 2011
    1200 bucks wth damn
    2 CHANNEL
    Under construction
  • JimBRICK
    edited June 2011
    I was think about the Jolida JD1000RC . Very nice looking, Anyone spent some time with one? Oh and I'll buy that Manley off anyone for 1200 right now :)
    2 CHANNEL
    Under construction
    edited June 2011
    You need to consider, auto-bias, fixed bias or manual bias. I prefer manual with auto being a close second. Not a fan of fixed bias tube amps.
  • JimBRICK
    edited June 2011
    I wish I never had sold my onix sp3. Worst audio decision I ever made
    2 CHANNEL
    Under construction
  • zingo
    zingo Posts: 11,258
    edited June 2011
    Grant Fidelity is offering a new 40wpc, KT88 based PP integrated called the W30GT which has an integrated 12AX7 phono stage, as well as an integrated 24/192 DAC section. Initial reviews are good, and even Klipsch people like the sound even though it is push-pull. It looks like a great all-in-one solution.
    edited June 2011
    JimBRICK wrote: »
    1200 bucks wth damn
    Yeah, Manley about doubled their prices on everything in the lineup a couple of months back, IIRC. Not sure how that affected the used prices though. Great piece if you can find one.
  • Face
    Face Posts: 14,340
    edited June 2011
    Lasareath wrote: »
    Very hard to find. I wish i bought Ted's! I could sell it for $4500 today
    Real classy.
  • Face
    Face Posts: 14,340
    edited June 2011
    treitz3 wrote: »
    According to the Agon Blue Book, it doesn't appear to have affected the prices of the original Stingray. If anything, the resale of the original has declined slightly since the debut of the Stingray II.
  • decal
    decal Posts: 3,205
    edited June 2011
    Rogue Audio Tempest II Magnum
    edited June 2011
    Oh, I didn't realize they introduced another Stingray. Any difference between the two that you know of?
  • dkg999
    dkg999 Posts: 5,647
    edited June 2011
    Cayin
    DKG999
  • Face
    Face Posts: 14,340
    edited June 2011
    They added a remote and made it look not nearly as sexy: http://www.manleylabs.com/containerpages/stingray2.html
  • madmax
    madmax Posts: 12,434
    edited June 2011
    Face wrote: »
    Try getting hold of one... The thing about manley is that even though they were not cheap before the price raise, they offered more than the price would suggest.
    Vinyl, the final frontier...
  • cubdog
    cubdog Posts: 835
    edited June 2011
    JimBRICK wrote: »
    I wondered about that. Sold mine as well. So far no regrets.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited June 2011
    JimBRICK wrote: »
    90WPC Magnum $2,195
    90 WPC
    - 4 and 8 ohm taps
    - 18? W X 17.5? D X 5.5? H
    I would highly recommend this amp,it is something special,at least to my ears.
  • george daniel
    george daniel Posts: 12,096
    edited June 2011
    aside from the usual suspects,,Rogue,Manley,,and given the efficiency of your speakers,,have you thought about any of the 2A3 or 300B offerings?
