Plasma TV's assistance
13»
    billbillw Posts: 7,563
    edited June 2011
    ajanzalone wrote: »
    Thanks Steve & Bill:
    i considered a used AV Receiver but not sure if they will accept a Toslink input ... and of course find a unit with a 2 channel pre out .....
    how I long for the days of simplicity & TV's with RCA outs ...lol
    Tony
    Nearly every AV receiver that has Dolby Digital/DTS processing will have optical input. That should be just about anything from from the last 10 years.
    It is a bit more tricky finding one with preouts though. Most will have 5.1 preouts. You would just use the Front R/L and set the receiver up to be in stereo mode with large full range speakers in the front. The receiver will then down-mix the 5.1 mix to 2-channel and output through the preouts.
    One might think that the Tape output would work, but most digital AV receivers will not convert digital signals to analog for the tape out.
  • ajanzalone
    ajanzalone Posts: 128
    edited June 2011
    billbillw wrote: »
    Bill:
    So I could connect my Quad Stereo amp mains, to the Front L & R RCA's on a multi channel pre/ processor ... ?
    That may be the way to go ...
    Tony
    Audio Research SP5 Preamp
    Quad 405 Amp
    Pioneer Elite DV-48AV -
    Outlaw 950 preamp/processor
    Polk Monitor 10's
    Velodyne VRP 1200 Sub Woofer
    Success is having what you want ... but Happiness is wanting what you have!
    edited June 2011
    ajanzalone wrote: »
    Bill:
    Tony
    Yeah, but a 10-12 year old mid-fi receiver would probably be cheaper than a pre-pro. Find an old Denon 28xx series or similar quality. Might be able to find one used on CL for $100 or less. People are dropping the old receivers like flys to get newer ones that can do HDMI, HD audio decoding, and 3D.
  • ajanzalone
    edited June 2011
    I just purchased the Outlaw Audio 950 pre/proc on polk classifieds ...
    http://www.polkaudio.com/forums/showthread.php?p=1596521#post1596521
    it also has a bypass for analogue ..... once I get it all figured out I will let you know ..
    I am curious to try this out,
    my Panasonic st30 series has the ability to use SD cards
    I tried a 720p .mkv file via the sd card and it played the movie in hi res and it was fantastic, clear and detailed picture ....
    so with that in mind i will try to add the toslink out audio to the new preamp/proc and see what I get ...
    who knew? ...lol
    I am an infant with all this updated technology
    Tony
    Quad 405 Amp
    Polk Monitor 10's
    edited June 2011
    ajanzalone wrote: »
    who knew? ...lol
    Tony
    That should work nicely. The output from the TV will either be Dolby Digital, or PCM audio. The Outlaw can handle either one and downmix it to 2-ch for your system.
