No sound from Polk Lsi9 Cherry speaker (Right channel)
kasuza
kasuza Posts: 29
edited June 2011 in Troubleshooting
I don't hear any sound from my Polk Lsi9 Cherry Right channel but only vibration sound from 2 woofer and tweeter. The left channel is fine. I don't know what wrong with Polk Lsi9 right channel. Even worst that i don't have original package to ship it to Polk Audio.
Samsung UN46C8000
Integra DTR-70.2 9.2 channels receiver
Martin Logan Source Special Edition Front (Dark Cherry)
Polk LsiC Center speaker (Ebony) (no Cherry):frown:
Polk Lsi9 Surround (Dark Cherry)
Polk Lsi7 Back Surround (Dark Cherry)
Polk Micro PSW3000 Subwoofer
Sony Playstation 3
Thermaltake DH 103 case HTPC
Post edited by kasuza on
    F1nut Posts: 51,817
    edited May 2011
    Hook up the suspect speaker to the left channel. If it still doesn't play, the problem is with the speaker. If it does play, you need to look elsewhere.
  • kasuza
    kasuza Posts: 29
    edited May 2011
    Still no sound but only hear vibrations from woofer and tweeter. I don't know what is going on with my lsi9. I am not sure if the problem is crossover, woofer, or tweeter.
    Samsung UN46C8000
    Sony Playstation 3
    F1nut Posts: 51,817
    edited May 2011
    What do you mean by "only hear vibrations"?
  • kasuza
    kasuza Posts: 29
    edited May 2011
    There is no sound coming out of right channel when listening music or movie. I only see woofer and tweeter vibrates. The left channels is working fine.
    Samsung UN46C8000
    Sony Playstation 3
  • apphd
    apphd Posts: 1,514
    edited May 2011
    kasuza wrote: »
    I don't hear any sound from my Polk Lsi9 Cherry 1 Right channel but only vibration sound from 2 woofer and tweeter. The left channel is fine. I don't know what wrong with Polk Lsi9 right channel. Even worst that i don't have original package to ship it to Polk Audio.
    2Hook up the suspect speaker to the left channel. If it still doesn't play, the problem is with the speaker. If it does play, you need to look elsewhere.
    kasuza wrote: »
    3 Still no sound but only hear vibrations from woofer and tweeter. I don't know what is going on with my lsi9. I am not sure if the problem is crossover, woofer, or tweeter.
    kasuza wrote: »
    There is no sound coming out of 4 right channel when listening music or movie. I only see woofer and tweeter vibrates. The left channels is working fine.
    So you are saying that after you switched the L & R speaker the RIGHT channel still was defective? If so. Check all your connections, amp source etc. it is not the speaker.
  • kasuza
    kasuza Posts: 29
    edited May 2011
    I switched receiver from Denon AVR-4310CI to Yamaha RX-A1000 and still have a same problem on the speaker. :confused:
    Samsung UN46C8000
    Sony Playstation 3
    treitz3 Posts: 20,018
    edited May 2011
    You did switch the left and right speakers [changing nothing else] to help isolate the problem, correct?
    F1nut Posts: 51,817
    edited May 2011
    You should not be able to see a tweeter vibrate.
    Anyway, I suspect that the 5 watt resistor on the tweeter circuit has cooked. You'd be surprised how little sound there seems to be without the tweeter working.
    Remove the binding post plate to gain access to the crossover. Look at the resistors, you should see one that looks burnt. If that is the case it will need to be replaced. Unless you can do board repairs you will need to have the crossover fixed by someone else.
    tonyb Posts: 33,072
    edited May 2011
    treitz3 wrote: »
    Simple questions deserve simple answers. I'm with ya Tom, no sense in pulling the crossover without making sure first. Jesse's probably right anyway. I know he has a pretty beefy receiver,but I don't see an amp in his sig. Very possible he cranked on it a tad too much and poof.
  • kasuza
    kasuza Posts: 29
    edited May 2011
    I am going to file RMA. I hope these speakers still have warranty. :Crossfinger:
    Samsung UN46C8000
    Sony Playstation 3
    edited May 2011
    Dude, we are trying to help you isolate the issue here. Answer one question for me, please. Have you switched the left and right speakers [changing nothing else]?
    Help us to help you. If you don't answer the questions asked, we can not help you.
  • BeefJerky
    BeefJerky Posts: 1,320
    edited May 2011
    I agree with treitz3. This is an important question that needs to be answered. Besides, if there is an issue somewhere else in the chain you may just end up destroying the replacement speaker too.
    F1nut Posts: 51,817
    edited May 2011
    Guys, I get the impression that English is not kasuza's first language, hence the communication issues.
  • kcoc321
    kcoc321 Posts: 1,788
    edited May 2011
    Kasusa: looks like you had a problem a couple of weeks ago with the Left Speaker.
    http://www.polkaudio.com/forums/showthread.php?p=1575275&highlight=LSi9#post1575275
    Might be something else going on, if you have the same problem on different. speakers.
  • apphd
    apphd Posts: 1,514
    edited June 2011
    yasimi reported ^^^^
