USB Transports/DACs
zingo
I am finally upgrading my digital transport after a few years, which tells you just how good of an entry level USB device both of these Musiland components are. The 01USD has been my main-stay for USB digital transport to feed my DAC, and I love it because it doesn't need an external power supply. The 01US has been doing headphone duty, and even spent time as a DAC in my system when I was between DACs. The custom drivers allow ASIO, plus custom setting for using them as a sound card with volume control, or as an independent transport. They are both great little units, and nothing can touch them for the price, especially since they can accept signals up to 24bit/192kHz. If you have been thinking about getting into PC audio, there is no better or cheaper way.
Musiland Monitor 01 USD
High speed USB connection
Independent APU MU6010 for 24 bit/192kHz audio processing
High quality S/PDIF transmitter
Optical, RCA coaxial or BNC coaxial digital output
PLUSE high quality digital power management
Support 24bit/192kHz digital output
Specialized ASIO driver - support Windows XP, Windows Vista and Windows 7
Aluminum alloy chassis for minimum interference
Interface: USB 2.0
Maximum sampling rate: 24bit/192kHz
Digital output: Optical toslink, RCA and BNC coaxial
Digital S/N: 140dB (A-weighted)
Digital dynamic range: 140dB (A-weighted)
Optical toslink digital output
Stereo RCA, 3.5mm headphone analog output
Interface: USB 2.0
Analog output: Stereo RCA, 3.5mm headphone
$55 shipped for each one including USB cable and disc with latest drivers.
Interface: USB 2.0
Interface: USB 2.0
Post edited by zingo on
I'll take the Musiland Monitor 01 US. Is it the one in your first 2 posted pics? It's for the wife's computer karaoke setup :biggrin:Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Yes it is"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I'll take the other...."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Monitor 01US pending to DMara.
You're just a savior, Jake!!! Just about an hour before you posted the sale I was browsing the Gon for a little dac, then kinda leaning toward the HRT Music Streamer II, but finally was glad to be able to say: I just saved a bunch of money on my karaoke dac by switching to zingo :biggrin:Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
