How long does it take to burn in a set of Odyssey amps?
VR3
The same amount of times it takes to wear a set of tubes!
Microphonics, microphonics, microphonics! GRRRR
Post edited by VR3 on
Vr3MxStyler2k3 wrote: »The same amount of times it takes to wear a set of tubes!
I thought they burned up, errrrrr......in pretty quick.:biggrin:Testing
Testing
Testing -
Right before they catch on fire.
"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
hehe
I sat down to listen and Im like - man something sounds off. Get up and tap on the Candela and HOLY JESUS!
Mullard NOS with the square getter ordered baby! YEAH!
I think this means one thing - might as well put this baby on repeat until the new ones get here so everything is nice and burnt in!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No spare tubes . . . rookie.
Im cheap- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Not in your crossovers you aren't.
Didn't I send you some tubes? You need more au7 varieties?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I ordered a few from you - I will admit they did not tickle my fancy! But they are in the drawer -
My favorite so far is RCA blackplates (I believe that is their designator) D-Getter? Sound right?
Mullard has been a constant I keep seeing so I ordered a set...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
After further listening part of what I was hearing (thankfully my ear infection is now gone and I could lay my ears on it)
The inductors that I changed out changed the crossover point and I was hearing some muddiness in the upper midbass that I was not digging... but my tubes are also bad...
All in all I cant win!
haha
I threw the old inductors back in and this verified my thoughts on the crossover point changing...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
A change in DCR can transfer function and overall driver efficiency, it doesn't change the point per se."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Its hard to explain.... but there is this one song I use for a reference of "midbass control" and there was a modulation effect with the new inductors...
The old inductors removed/reduced this effect.
Either way I like the old inductors for now...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I meant to say above, "can affect transfer", but I believe you got the gist of it.
How big of a difference in DCR was there?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
This would IMO only be apparent in the shunt position of a high pass network where yes a change in resistance can change the shape of the knee at roll off.In series with a woofer I would think your only altering the voltage sensitivity and electrical Q(Qes) of the woofer."can affect transfer" -
Some of the values were right on a 10% change while the other was spot on- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
