How long does it take to burn in a set of Odyssey amps?
VR3
VR3 Posts: 29,384
edited May 2011 in 2 Channel Audio
The same amount of times it takes to wear a set of tubes!
Microphonics, microphonics, microphonics! GRRRR
Post edited by VR3 on
  • Systems
    Systems Posts: 14,873
    edited May 2011
    I thought they burned up, errrrrr......in pretty quick.:biggrin:
    Testing
    Testing
    Testing
  • pearsall001
    pearsall001 Posts: 5,222
    edited May 2011
    Right before they catch on fire. :wink:
    VR3 Posts: 29,384
    edited May 2011
    hehe
    I sat down to listen and Im like - man something sounds off. Get up and tap on the Candela and HOLY JESUS!
    Mullard NOS with the square getter ordered baby! YEAH!
    I think this means one thing - might as well put this baby on repeat until the new ones get here so everything is nice and burnt in!
  • SolidSqual
    SolidSqual Posts: 5,218
    edited May 2011
    No spare tubes . . . rookie.
    VR3 Posts: 29,384
    edited May 2011
    Im cheap
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2011
    Not in your crossovers you aren't.
    Didn't I send you some tubes? You need more au7 varieties?
    VR3 Posts: 29,384
    edited May 2011
    I ordered a few from you - I will admit they did not tickle my fancy! But they are in the drawer -
    My favorite so far is RCA blackplates (I believe that is their designator) D-Getter? Sound right?
    Mullard has been a constant I keep seeing so I ordered a set...
    VR3 Posts: 29,384
    edited May 2011
    After further listening part of what I was hearing (thankfully my ear infection is now gone and I could lay my ears on it)
    The inductors that I changed out changed the crossover point and I was hearing some muddiness in the upper midbass that I was not digging... but my tubes are also bad...
    All in all I cant win! ;) haha
    I threw the old inductors back in and this verified my thoughts on the crossover point changing...
  • Face
    Face Posts: 14,340
    edited May 2011
    A change in DCR can transfer function and overall driver efficiency, it doesn't change the point per se.
    VR3 Posts: 29,384
    edited May 2011
    Its hard to explain.... but there is this one song I use for a reference of "midbass control" and there was a modulation effect with the new inductors...
    The old inductors removed/reduced this effect.
    Either way I like the old inductors for now...
  • Face
    Face Posts: 14,340
    edited May 2011
    I meant to say above, "can affect transfer", but I believe you got the gist of it.
    How big of a difference in DCR was there?
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    Face wrote: »
    This would IMO only be apparent in the shunt position of a high pass network where yes a change in resistance can change the shape of the knee at roll off.In series with a woofer I would think your only altering the voltage sensitivity and electrical Q(Qes) of the woofer.
    VR3 Posts: 29,384
    edited May 2011
    Some of the values were right on a 10% change while the other was spot on
