KEF's new flagship, pretty interesting design...
  • Systems
    Systems Posts: 14,872
    edited June 2009
    halenhoang wrote: »
    KEF is an amazing speaker line. Ask B&W, they took KEF"S design and made it there own, you could see it in all of their 800 series line.
    Halen
    Are you talking about the old KEF Reference 105's with the robotish looking tweeter/ midrange module vs the original B&W 801's?
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    edited May 2011
  • newrival
    newrival Posts: 2,016
    edited May 2011
    Keiko wrote: »
    I think they look pretty cool. I'd like to give them a listen. The driver design, force cancelling concept is interesting.
    It's not new technology, it's called a bipole. Additionally, there have been a number of subwoofer builds that utilize the same bolted/mounted sub drivers. It's definitely advantageous, but it's well established and produced tech.
  • rromeo923
    rromeo923 Posts: 1,513
    edited May 2011
    My friend happened upon some KEF 107/2 for free.
    One of the tweeters doesnt work, no sound. Any ideas?
    I got static in my head
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    While the baffle shape has acoustic advantages it's a little too techy looking for my tastes.A nice wood veneer would improve the looks IMO.
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    rromeo923 wrote: »
    Those 107/2 are nice,just the bad tweet everything else works?If so the voice coil may be burnt (or open)or a failed passive component in the tweeters crossover circuit.
    But since the world is going to end tommorow and they have a wonky tweeter have him ship them to me.:wink::smile:
  • rromeo923
    edited May 2011
    Seemingly everything works. The one good speaker sounds really nice. The other doesnt even sound too bad w/out a tweeter ( well not really ). So how extensive and costly will a replacement be? Any idea?
    BTW, Those new KEF are cool looking and I would love to hear them.
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    rromeo923 wrote: »
    I'm not sure of cost or availability but you might try contacting these guys.http://kef.com/us/Contact
    If a replacement is available I expect it to be spendy,but that is a speaker probably worth fixing,especially so since they were freebies.(btw. did they come with the separate KUBE bass equilizer.)
    However before anything you need someone competent to do some trouble shooting to confirm if it is even the tweeter thats at fault and not a failed resistor or cap in the crossover etc.The simplest thing would be to swap tweets between cabinets.Great care would be needed so as to not dent the delicate metal domes,otherwise they would be junk.Also care is needed when removing the protective grille in front of the tweeter.If the tweeter checks out ok someone in the know will have to trouble shoot the crossover.
  • rromeo923
    edited May 2011
    No Kube. We switched the two tops and still same prob w/that specific top.
    Switching out the actual tweet is a good idea. However competence is probably not my middle name. So I will prob suggest getting someone who knows what to do involved.
    Thanks for the advice.
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    rromeo923 wrote: »
    No Kube.
    Ouch,that hurts.It's a must to get the full bass extension they are capable of.
    But you would also be swapping the crossovers at the same time as I believe the midrange and tweeter crossover components are mounted inside the heads.
