5.1 with separate multi-channel amp?
footwedge
footwedge Posts: 475
Is it better to have more power going to the L&R fronts and less power going to the center and rear surrounds? or just power them all the same? I just do not hear enough out of the surrounds to power (spend $) them the same. Looking at a W4s amp for LSI 7s & C front stage and LCI60 in wall rear surrounds.
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2011
    All speakers benefit from more power, and since you are running an all LSI system, they would benefit greatly with a 5 channels amplified.
  • newrival
    newrival Posts: 2,016
    edited May 2011
    cfrizz wrote: »
    absolutely not.
    How much power does the LCI60 need, exactly then?
    It's a 91db efficient speaker how much power would be sufficient?
    In fact, many upper-echelon HT amps designate LESS power to the surrounds.
    edited May 2011
    newrival wrote: »
    absolutely not.
    It's about current my man. My speakers are 95db efficient, but without some juice they would sound flat. Heck, even Klipsch at 102 db efficient, people run amps on them. What a speaker needs to get by and what it wants can be 2 different things. Sure isn't going to hurt them none to throw an amp into the mix.
  • newrival
    edited May 2011
    Footwedge, as you mentioned, there isn't a ton of information that goes through the surrounds. Also, center channels are subject to all the dynamics and carry much of the heavy lifting of the HT signal and often as demanding or even more demanding of the amplification section as/than the front L & R channels.
  • newrival
    edited May 2011
    tonyb wrote: »
    I agree and I'm well aware of the current issue. we're talking about the surround channels here. He's asking if he can dedicate less power to the rears or if they are equally demanding as the front. The answers are yes he can because no theyre not.
    edited May 2011
    True....at least amp the front 3 speakers and let the receiver do the surrounds. The center handles a good portion of movie soundtracks.
    Still, if the opportunity came up for a 5 channel amp, I wouldn't look the other way either.
  • footwedge
    edited May 2011
    I'm looking at a W4s multichannel amp (3x250, 2x125 8 ohms, 3x550 , 2x220 4 ohms). Thinking this will be a little less expensive than a 5x250 if it will be ok.
    Also looking at the rotels, but since there are no dealers within 500 miles, I'm leaning towards having the W4s delivered to my door.
  • newrival
    edited May 2011
    Wyred 4 Sound over the rotels every day of the week.
    The staggered wattage amp will be perfect (the 3x250,2x125)
    W4S is an order of magnitude better than rotel offerings
