Q's of my new speakers
Gotcha... missed the fact that you have a sub.
Ask yourself this though... If you are truly happy with the Paradigm, then why are you missing the bass? The answer is that huge open listening area you have.
Not implying SVS is the only solution, but your existing sub needs some help.... and I'll maintain that the 150's aren't it.
As for the towers, that was poorly worded on my part as I knew they were out of the picture now. I was thinking a 7.1 rig with the f/x 30's as rears and 50's as sides...
Do you like the 30's in bi or di-pole mode as rears?More later,
Tour...
Vox Copuli
Tour, I'm very happy with my Paradigm sub, I don't think the House could handle anymore sub if there was such a sub. I don't think so, maybe I can start a new tread. Paradigm Servo-15 RULES.
I must put my self with the No sub in music people. So with this I do think the 150's or the 12's fill the void.
As for as the FXi30's Bi-Pole over Di-Pole for me in the position you seen.Originally posted by Tour2ma
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Gotcha... 12's would get my vote unless vintage floats your boat...More later,
Tour...
Vox Copuli
Just like the look better or was it price ??
I do think it will not be the end of it. I think about a $1200+ used amp should do it. Then either my wife will kill me or I just go deaf? 50/50:)
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Neveer spent much time with the 12's or 150's, but what I did spend I like the sound of the 12's... but the look of the 150's...
12's are OK as long as the grills stay on.
What amp do you have in mind?More later,
Tour...
Vox Copuli
Amp, a Bryston 4b or Parasound ? I need to go listening one day to see want I like.........
BTW 5.1 cool with my room? no 7.1? Just trying to get your side of this. Also want is the proper height for the FXi30's?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Height couple feet above ear level... play with them some if you can before commiting to permanent mount.
Big, long room... 7.1 should make the transitions from front to rear and vice versa smoother.
Bryston or Parasound, huh? Good "sound" stuff there...More later,
Tour...
Vox Copuli
