4 ohm or 8 ohm?
charley95
charley95 Posts: 908
edited February 2012 in Vintage Speakers
I spoke with the maker of my amp today to question that my amp is common ground. He stated that it is. Rogue Cronus/Magnum integrated 90WPC.
He asked what speakers I'm using,[2.3's] running on the 8 ohm output on the amp. He recommended I use the 4 ohm tap instead. He stated it might have a small amount of sound improvement. Any thoughts on this? 4 ohm vs. 8 ohms? My knowledge on this is limited.
Thanks!
Post edited by charley95 on
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited May 2011
    charley95 wrote: »
    Thanks!
    I believe the 2.3's are 4 ohm speakers.
  • charley95
    edited May 2011
    Mine are 6 ohm.
  • audiocr381ve
    edited May 2011
    He's right, use the 4 ohm tap.
    heiney9 Posts: 25,504
    edited May 2011
    Try it and see........if it were me I'd run the 4ohm tap.
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2011
    I would run the 4ohm tap as well. 2.3's are 6ohm nominal and drop below it easy.
  • charley95
    edited May 2011
    heiney9 wrote: »
    Made the switch, no difference that I can tell.
  • audiocr381ve
    edited May 2011
    charley95 wrote: »
    I thought that would happen :smile:
    You might hear a difference at higher volumes?
  • george daniel
    george daniel Posts: 12,096
    edited May 2011
    some say the 4 ohm tap may provide better bass control--dunno the specific's,but I seem to prefer the 4 ohmer myself.YMMV--good luck.
  • drselect
    drselect Posts: 664
    I was reading DK post http://www.polkaudio.com/forums/showthread.php?129829-The-AI-1-Dreadnought-Project-Pt.2-Upgrade-to-1000VA-Transformer about the AI-1 Dreadnought and noticed under his equipment listing "Polk Audio SDA CRS+ loudspeakers (extensively modified), 4 ohms nominal impedance." This made me wonder what he had done to "convert" the 6 ohm CRS+ to 4 ohm. So thinking I might have another tweak to try I put my limited search skills to use and found this thread http://www.polkaudio.com/forums/showthread.php?73321-SDA-CRS-Mono-Modification-Advice& were DK state "I rewired the CRS+'s dimensional drivers to be in parallel with the stereo drivers. This dropped the nominal impedance from 6 to 4 ohms...".. Not sure if this was what he was referring to in the AI-1 thread I kept searching and came upon a thread from 2009 http://www.polkaudio.com/forums/showthread.php?91906-SDA-CRS-6-ohm-Question and this thread were in 2009 F1nut and in this thread H9 state try using the 4 ohm and the 8 ohm tapes with the CRS+. Well since I have since my tube amp has 4 ohm taps I decided to give it a try. And I am glad I did. It was clear to me that the 4 ohm tapes on my amp gave more punch to the bass. I am been listing to Dvorak "New World Sympony" and really enjoying the improvement in the sound. I have not noticed any roll off in the highs like was suggested in other forums post I came across while doing searches. So thanks DK, F1nut, and H9. And now back to the music.
  • lanchile
    lanchile Posts: 560
    The only difference between 4 ohms or 8 ohms speakers is just the impedance!!! sound will be the same. The bad part is for the amp, it will work harder at 4 ohms (nothing to do with sound again) as long the impedance is not lower then amp specifications is ok. all depends how low speaker impedance your amp can take. The safest for an amp is usually 8 ohms, but some go down to 4 ohms and rare can take 2 ohms (talking about home amps here). again impedance has nothing to do with sound quality!!!!
    Make it simple...Make it better!
  • drselect
    drselect Posts: 664
    lanchile wrote: »
    I just checked and I am free tomorrow afternoon, would you like to come over and have a listen for your self?
  • lanchile
    lanchile Posts: 560
    drselect wrote: »
    Sorry, tomorrow and all this week I will be busy BUILDING an amplifier for my friend. Did I mention that I build amplifiers?:cheesygrin:
  • lanchile
    lanchile Posts: 560
    This is my diy amplifier. Attachment not found.
    F1nut Posts: 52,002
    Sure it does. I think what you failed to take into account here is that we're talking about tube amps and matching the impedance of the amp to the speakers definitely affects the sound quality.
  • jbaker
    jbaker Posts: 6
    It made a huge difference on my setup. Read from the following link below. The forth post is where I talk about the benefits I just got. http://www.polkaudio.com/forums/showthread.php?129980-RT600i-ohm-question
  • drselect
    drselect Posts: 664
    lanchile wrote: »
    Sorry you can't make it. Nice looking amp. Sort of looks like the one I have.
    By the way.... "Tube Rule".....:cheesygrin:
  • CoolJazz
    CoolJazz Posts: 572
    lanchile wrote: »
    Impedance matching on a tube amp is to maximize power transfer and minimize distortion both! Tubes are forgiving with the swinging impedance speakers present, but lowest distortion with most power transfer is at a specific value for every tube at it's operating voltages. The load the tube operates into is that varying impedance of the speaker through the ratio of the output transformer.
    Using the correct tap does give you the best situation for control over the drivers and minimizing distortion.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • rromeo923
    rromeo923 Posts: 1,513
    I have tube amp. I have SDA 1C (6 ohm). I tried 4 and 8 ohm and ended up like 8 ohm sound better. Very little difference though. IMHO
    I got static in my head
  • lanchile
    lanchile Posts: 560
    drselect wrote: »
    Maybe you are right about that, but some people can build diy amps that will put those commercial amps on shame. take a look of this post http://www.diyaudio.com/forums/pass-labs/166784-pictures-your-diy-pass-amplifier-109.html
