Interconnects; a novice question
Slaine777
Slaine777 Posts: 78
What is the difference in function between interconnects and cables? I understand there may be a quality difference between products called interconnects and ones called cables, but they preform the same function, right?
  • renowilliams
    renowilliams Posts: 920
    edited April 2011
    I think cables refer to cables for speakers and interconnects refers to cabling between components ie: a cable between an amp and pre-amp.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • punk-roc
    punk-roc Posts: 1,150
    edited April 2011
    IC = interconnect cables = interconnects = cables
    not to be confused with speaker cables
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2011
    punk-roc wrote: »
    And,
    IC = integrated circuit
    That is the first translation my brain does when I see 'IC' in a sentence. Then it goes to the cable definition. :rolleyes:
  • Slaine777
    Slaine777 Posts: 78
    edited April 2011
    Ok, thank you. I'm used to calling interconnect cables by their connection type, i.e. HDMI, component, RCA, etc.
