what subwoofer is the best match
dekuleaf
hello my friends
i have a pair of rt800 floor standing speakers what subwoofer should i buy?
Post edited by dekuleaf on
You have so many choices it's not funny but if you want a sub that can do both music and movies extremely well then I suggest getting a Velodyne DD-10 or 12.
You can shop around check out all the offerings from so many companies to your blue in the face but the DD series from Velodyne are rock solid and will do the job better then most.Dan
ill take that into consideration
I would look at one of the servo controlled subs from Rythmik Audio for a sub that does both music and HT. For less money then the Velodyne DD-10 (~$1800) I think you can get better SQ and more output with Rythmik.
Now if your after a really small foot print then Velodyne is a great choice. Is it form factor or function or both that you are after. -
Two channel, HT or a combination of both and what's the budget?
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
my budget is around 500$
Bump it up a little more and go with Epik subwoofers or something from SVS.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Is it for Music? Is it for HT? What are your room dimensions? Can you hold a screwdriver? Do you mind used? Can you DIY? -
What do people think about the Emotiva ultra Sub 12 or the Velodyne Impact. I currently have the PSW 505 and am looking to upgrade. The 505 does well for the price and most instances, but it flubbs out on quick tight bass.
Search Audiogon for used Subwoofers in your price range.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
i have noticed however that i can get two psw110a's for the price of just one psw125.(if i shop around) could someone comment on this statemaent please? and aslo it is for my bed room 12 by 16 feet and i am good with tools of all sorts.
sorry i ment psw110's
This sub may work for you.
http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1309118232&/REL-t2-black-new-low-priceLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
