what subwoofer is the best match
dekuleaf
dekuleaf Posts: 26
hello my friends
i have a pair of rt800 floor standing speakers what subwoofer should i buy?
  • mantis
    mantis Posts: 17,689
    edited April 2011
    You have so many choices it's not funny but if you want a sub that can do both music and movies extremely well then I suggest getting a Velodyne DD-10 or 12.
    You can shop around check out all the offerings from so many companies to your blue in the face but the DD series from Velodyne are rock solid and will do the job better then most.
    Dan
  • dekuleaf
    dekuleaf Posts: 26
    edited April 2011
    ill take that into consideration
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    I would look at one of the servo controlled subs from Rythmik Audio for a sub that does both music and HT. For less money then the Velodyne DD-10 (~$1800) I think you can get better SQ and more output with Rythmik.
    Now if your after a really small foot print then Velodyne is a great choice. Is it form factor or function or both that you are after.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    Two channel, HT or a combination of both and what's the budget?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • dekuleaf
    dekuleaf Posts: 26
    edited April 2011
    my budget is around 500$
  • kawizx9r
    kawizx9r Posts: 5,150
    edited April 2011
    Bump it up a little more and go with Epik subwoofers or something from SVS.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • jinjuku
    edited April 2011
    dekuleaf wrote: »
    Is it for Music? Is it for HT? What are your room dimensions? Can you hold a screwdriver? Do you mind used? Can you DIY?
  • BtrSound
    BtrSound Posts: 123
    edited April 2011
    What do people think about the Emotiva ultra Sub 12 or the Velodyne Impact. I currently have the PSW 505 and am looking to upgrade. The 505 does well for the price and most instances, but it flubbs out on quick tight bass.
  • danz1906
    danz1906 Posts: 5,144
    edited April 2011
    Search Audiogon for used Subwoofers in your price range.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • dekuleaf
    dekuleaf Posts: 26
    edited April 2011
    i have noticed however that i can get two psw110a's for the price of just one psw125.(if i shop around) could someone comment on this statemaent please? and aslo it is for my bed room 12 by 16 feet and i am good with tools of all sorts.
  • dekuleaf
    dekuleaf Posts: 26
    edited April 2011
    sorry i ment psw110's
  • danz1906
    edited April 2011
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited April 2011
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
