Sub adjustment
I have a PSW505 sub which I quite like. However it was bottoming out when I watched the new Tron Blu Ray.
I know the 505 has it's limitations, but is there anyway to tweak it to perform better for bass heavy movies?
Tks.
Tks.
Onkyo HTRC 180
Polk Monitor 70 Series 2 Fronts
Polk CSi A6 Center
Polk PSW505 Sub Woofer
Polk Monitor 60 Series 2 Surrounds.
Harman Kardon HTSK18 Back Ceiling Mounted
PS3 Xbox
Polk CSi A6 Center
PS3 Xbox
Maybe first let us know how you have the sub setup and/or what crossover point your using. Do you just have one cable from sub out on the receiver going to the sub ? Are your front speakers set to large or small ?
How big is the room ? Did you play around with placing the sub in different positions ? A tad more info my friend would help your responses.HT SYSTEM-
lsi 9's -
Thanks Tonyb.
It is set at 80 hz for cross-over. Just one cable from sub to receiver. Speakers are set up using Audeyssy EQ. Room is 12 by 24. I haven't moved it as it seems fine for other movies.
I did read that Tron goes pretty deep for bass. The 505 seems to bottom out.
Tks.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox -
Turn down the volume on the back of the sub, don't let it keep bottoming out or you'll be shopping for a new one quicker than you think. Everything has it's limits bro.HT SYSTEM-
lsi 9's -
It does have a Low Pass Filter setting on the back (between 60 and 120hz). What should that be set at?
I guess I will probably just have to turn it down. Although if it does break, it will be fun to upgrade.Onkyo HTRC 180
Polk CSi A6 Center
PS3 Xbox
