do 2 sub really make difference compared to just one?
Mr Glide
Mr Glide Posts: 29
edited May 2012 in Speakers
Hi,
I have Polk 7.1 HT setup which consists of PSW505 sub. I am considering to adding 2nd sub. My questions:
1. Is this a good idea for mid size room (18 x 13 )? I am not looking for more loudness or anything like that as I am not huge fan of boomy, bass loud music, however, I am wondering whether adding 2nd sub improves bass notes (tighter, cleaner sound) while playing movies,etc?
2. For folks who have 2 subs, could you share your experience in general as to what changes/improvements have you noted in watching/listening to Blu-Ray movies with HD audio (e.g. DTS HD MST/Dolby TrueHD) and also while listening to music?
Thanks.
Post edited by Mr Glide on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2011
    After owning duals I'll never go single again.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    One is the minimum, four is best! Sounds like overkill, but if you read the following link, you'll see the reasons why.
    http://forum.blu-ray.com/subwoofers/
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Cmiller
    Cmiller Posts: 108
    edited April 2011
    leroyjr1 wrote: »
    Agree!..Im running dual subs now,alot better than when i had 1
    Samsung PN50B550 Plasma
    Pioneer Elite SC-25
    Pioneer Elite BDP-23FD
    Adcom 7500 Amp-Panamax 4300 Conditioner
    Polk RTi10's Fronts
    Polk Csi A6 Center-Polk M60s rear Surrounds
    Klipsch Synergy Sub-10 X2
    Klipsch Synergy S-10 Premium back surround
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2011
    leroyjr1 wrote: »
    d@mn you.....:tongue:
  • B Run
    B Run Posts: 1,888
    edited April 2011
    i had dual 505's in a really big room and they sounded great, definitely worth it for the price.
  • Slyder01
    Slyder01 Posts: 115
    edited April 2011
    i'm running 3 subs and will get another in the future. If your avr has a second sub out for the rear it does make a difference in HT. It's sounds much better when things come from the rear to the front with a rear sub, it brings that extra bass with it.. totally awesome! If you can afford it, get the second, you won't be dissappointed
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    Polk fxia6 Rear Surround
    Paradigm Micro Rear Back
    Onkyo bookshelf Front Presence (for now)
    PSW 450 Front Sub
    DSW MicroPro 4000 Front Sub
    DSW MicroPro 2000 Rear Sub
    Samsung c6300 60 inch LED
    Sony BDPs370
    Room Size 15x30
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    I have dual subs, much better than just one.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • B Run
    B Run Posts: 1,888
    edited April 2011
    The real question: is one high end sub better than 2 cheaper subs? Personally I went from dual Psw 505's to an SVS and it blows them away without a doubt. However mine is the 16-46 and I can't justify $1,000+ for a 2nd one (got mine used for dirt cheap). I miss having dual subs in the front, but this thing digs so low and hits so hard I wouldn't go back.
  • aboroth00
    aboroth00 Posts: 1,106
    edited April 2011
    B Run wrote: »
    Yeap one good sub will blow away crappy dual subs any day. The only reason you'd want to get dual subs is more for room response than for output. Sure you'll get a tad more output, but dual subs will help alleviate dips and peaks.
    I have ran singles, duals, triples, quadruple and there is a difference each time. However, if there is a weak link in your system especially with subs, it'll just degrade the SQ. More headroom is better but if one subs starts distorting for the other, then it's holding the whole system back. I'm currently only running duals but it's pretty great, as well as an EQ. I can go back to a single sub, and wouldn't mind too much, but it has to be one GOOD sub :smile:.
    2Ch Tube Audio Convert
  • Face
    Face Posts: 14,340
    edited April 2011
  • pearsall001
    pearsall001 Posts: 5,242
    edited April 2011
    You bet your sweet bippy two subs perform better than one...it's not even close.
  • Slaine777
    Slaine777 Posts: 78
    edited April 2011
    For those of you with two subs, where do you have them? Each side of the TV (for HT)? Opposing corners? Stacked?
  • DMara
    DMara Posts: 1,434
    edited April 2011
    Slaine777 wrote: »
    The best location for my dual subs in my living room is:
    Pic#1:
    Pic#2:
    They are shaking my sofa, literally :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • aboroth00
    edited April 2011
    Slaine777 wrote: »
    If you stack your subs, you won't get the benefits of placing your subs in different locations to smooth the room response. By stacking the subs you would probably get somewhere around 6db increase in gain, assuming the subs are identical of course.
    If you wish to improve room response, it is usually recommended you position your subs symmetrically. You can have mid-wall placement, either side or front, or corner placement in opposite corners. If you have 4 subs you can have it in all four corners or all 4 mid-walls.
    Personally for myself, placement wise, it was best that I placed the front sub slightly to the left of the center, 2 subs on the sidewall and one sub immediately behind the LP. I've since downgraded and only have two subs front and back. The FR is not as smooth as I had measured with the two subs on the side wall as expected.
  • over50
    over50 Posts: 201
    edited April 2011
    In reguards to subwoofer, would you expert users recommend isolation platform.
    Or would spike's be ok. My room is approximently 11X20 carpet.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    B&K ST.3140 Power Amplifier
    HSU Research VTF2 MK3
    Vizio P65-C1
    Panasonic 605 blu ray
    Onkyo DS-A4 i-pod Dock
    Universal Remote
    BDI Icon 9429 TV Stand
  • mantis
    mantis Posts: 17,322
    edited April 2011
    Face wrote: »
    Excellent read , thanks for sharing. I'm always interested in view points when it comes to sound pressure and filling a room as such.
    Dan
  • mantis
    edited April 2011
    DMara wrote: »
    Pic#1:
    Pic#2:
    I suggest wall mounting that center channel directly underneath your Display and getting it off the floor. It will perform better in that position. Or get a taler center channel stand if you don't wish to fish the wire inside the wall.
    I have hung many LSIC's on wall and always felt it performed better then free standing. The wall seemed to help improve mid bass performance.
    Dan
  • mantis
    edited April 2011
    As said in many different ways , adding a second sub is for coverage . It will help get rid of null spots in your room. More seats will have coverage then just with 1 sub.
    I run 2 subs and have considered adding a 3rd. But honestly I'm very happy with 2.
    Dan
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    When going the route of multiple subs get something to actively manage the subs if you can.
  • danz1906
    danz1906 Posts: 5,144
    edited April 2011
    jinjuku wrote: »
    Great advice!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2011
    jinjuku wrote: »
    That's very true, as multiple subs can have huge peaks or dips in the room frequency response (can even cancel each other out at certain frequencies). I am using dual NHT SubTwo subs with Velodyne SMS-1. Adding SMS-1 made a huge difference in the system. The bass response in my old room changed significantly - it literally shifted from left to more center/widespread bass (I was limited to keeping both subs in front, which is not a recommended setup).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • m60cs2
    m60cs2 Posts: 38
    edited April 2011
    My receiver is 7.1. Can I just use a Y rca splitter to add a second sub to go to 7.2? Or do I need 2 sub pre outs on the receiver?
  • jinjuku
    edited April 2011
    Yes you could.
  • Advantage
    Advantage Posts: 38
    edited April 2011
    Good question and often comes up as a subject of debate. I was too in your same situation a few months back. I would, of course, love Mantis' setup with dual JL Audio F113's; that would be the ultimate in my book. However, for the common man, I couldn't justify spending that sort of coin on subwoofers. Some day I'll convince my wife.
    I was between getting 2 Polk MicroPro 4000's versus 1 SVS PB13-Ultra. There are a few on this board that have 2 4000's and absolutely love them. You should read DarqueKnight's critique of the MicroPro 4000. It's a great read and very informative.
    For me, I ended up going with the 1 SVS and have really enjoyed it. Believe me, the output of this monster is unbelievable. It literally vibrates the dishes on the main level and the sub is in the basement. Of course, the room response I would suspect would be flatter had I gone the route of 2 4000's.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
    Love dual subs. Hey DMara love the Lovan M2 Center, I have the same one in my HT.
  • Toxis
    Toxis Posts: 5,116
    edited April 2011
    Say you already have a single sub and want a little better sound (not so much output necessarily). Would you rather add a second sub or add an SMS-1? This is something I'm thinking about currently...
    DMara wrote: »
    Pic#2:
    While I can't stop drooling over your setup, I got a chuckle at your thermastat. Time to get that paint back out... ;)
  • Mr Glide
    Mr Glide Posts: 29
    edited April 2011
    I recently acquired new PSW505. It's very powerful (300 watts), however, I feel find that my 15 year old Velodyne CT100 has tighter, cleaner bass (perhaps the new location where boomy PSW505 is now located makes it sound bit less desirable (?), will have to investigate).
    I hear everyone here saying is to get the same model of sub as 2nd sub. Since PSW505 being an obsolete model, I am don't know how long it's going to be available (out of stock these days at most internet sites). So, I need to make decision soon whether to pull trigger for 2nd one or not. Wish Polk folks let us know when they really plan to stop manufacturing their products.
    In any case, your input is appreciated. Seems like no one has done serious tests (e.g. using test CD,etc.) for 2 subs setup, but general consensus so far seems to be that 2 is better than one.
    Specifically, does anyone have 2 PSW505s in their setup? Care to share your experience?
    Also, is there such thing (test track, cd,etc.) available to see difference specifically between 1 sub and 2 subs in a particular setup?
    Thanks!
  • DMara
    DMara Posts: 1,434
    edited April 2011
    Toxis wrote: »
    Are you talking about moving the thermostat or are you talking about the paint?
    If it's about the paint around the thermostat, then it's just the shadow while taking picture, not a painting problem :smile:
    Now if you're talking about moving the thermostat, hmm, I'm lazy now :biggrin:
    Living room:
    Bedroom:
    Other rooms:
  • mak99
    mak99 Posts: 362
    edited April 2011
    Mr Glide wrote: »
    Some time ago, I had dual 505's...for about a day. While I liked the 505 in terms of price/performance, the physical size just looked goofy along the front wall, along with a Salamander Triple 20 rack and a pair of RTi70s. It looked like a used stereo store cramming everything they could along one wall.
    I ended up selling both 505's and eventually bought dual microPro 1000's. Their smaller size looked a bit better in the same locations as the 505's. I also liked their sound better, tighter and less boomy than the 505's. Sealed vs ported probably contributed to that... If you search my old posts, I gave my review of 505 vs microPro (IIRC), and also my review of dual microPros.
    Like others have mentioned, running duals will give you better distributed bass response across a larger listening area. The dual microPros seemed to do a great job of doing this...
    However, I ended up selling both the microPros just over a year ago and upgraded to an MFW-15, which gave much deeper bass output than the 1000's could ever think about. And in the last few months, that sub was upgraded with the Turbo kit (better driver + 1000w ext. amp) that takes the performance up near the "big boys". I'd love to buy another MFW/Turbo in the future to run duals...
    If you have the room and $$, buy another 505 from Newegg when they are priced at $200 shipped...
    Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!!
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2011
    I have dual subs, and what I discovered is that it will balance out the bass which will sound better. If you are in a tiny room, then 1 will suffice, however I would say in your size room having two subs would be a nice improvement.
