Cable Risers-- Yes, No, Maybe so??
Jer.War
Jer.War Posts: 180
edited April 2011 in DIY, Mods & Tweaks
Chime in if you like, but I noticed other threads like this
Thanks for stoppin' by though.
Anybody have any experience using cable risers to lift cable from the carpet? Noticed them while crusin' around Maplshade. They are not very costly, but I was just wondering what, those who have tried them, experienced soundwise, and what type was used.
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
Post edited by Jer.War on
  • mantis
    mantis Posts: 17,557
    edited April 2011
    Yes I have Installed them many times. The idea is to keep the cable away from static. Thats all. They work but I'm no fan. Unless you have bad static problems you don't need them. They look cool.
    Dan
    edited April 2011
    Wool carpet is terrible with static. Depends on the cable too. If you use unshielded cables,they may be more prone to picking up static. For the most part, as Dan said, not needed for most.
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2011
    Check my thread here: http://www.polkaudio.com/forums/showthread.php?t=99825&highlight=porcelain+cable
    Inexpensive. Also see my showcase for pics of them in action. Do they make a difference? I dunno, but they certainly can't hurt.
  • steveinaz
    edited April 2011
    The link in the original thread doesn't work anymore; try this one, and scroll towards the bottom of the page for less expensive pin insulators:
    http://www.electriciansupplies.com/index.cfm/S/373/N/13284/Victor_5R.htm
    Looks like they've gone up a couple bucks--but still way cheaper than buying thru an audio store. This one:
    http://www.electriciansupplies.com/product.cfm/p/95898/Victor-8R.htm
    Be patient, shipping is slow. I think mine took 2 weeks to get to me.
  • steveinaz
    edited April 2011
    Use this number instead, the other one requires a minimum order of 100ea:
    http://www.electriciansupplies.com/product.cfm/p/119933/Lapp-6183R-70.htm
  • nspindel
    nspindel Posts: 5,343
    edited April 2011
    Don't you miss the days when you could edit an older post?
  • steveinaz
    edited April 2011
    Yep, never understood the logic behind the decision to lock posts down.
