Onkyo 701 Owners
Pauly
Pauly Posts: 4,519
Got my new onkyo in and am pleased thus far...only had about 5 min play time and havent had chance to really play with but was wondering if anyone has a similar system than mine that has it calibrated. I can calibrate by my ear to my liking but was wondering what anyone else has theres set at until i get a spl to it. I left L,R,C,LS and RS @ 0db for now. I have 70's for fronts, 40 center and 28's rears. Any input would be greatly appreciated.
Spaz
Life without music would
  • faster100
    faster100 Posts: 6,124
    edited February 2004
    that depends all on the size room, But as a rule, start with your center on 0 ....... you could run left and right mains at +2 or so... surrounds just play it by ear until maybe we can get together with my Spl meter.. and set that svs up also..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Pauly
    Pauly Posts: 4,519
    so the fronts would beplaying at louder levels than the center :confused: or is that to make up for watching HT and most of the sound coming through the center.
  • faster100
    Thats how my system calibrated up.. The center is usually higher then the mains,(on a tv ) maybe in front or behind the mains a bit.. rarely straight inline and that's what makes the numbers slightly different i suppose.. make em all 0 if that makes ya feel better... really play it by ear.. but the meter is the true test. you may think they all sound the same,.., but the meter is 10x more accurate i would think. specially for the sub.. no way to play that by ear at all
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Pauly
    Pauly Posts: 4,519
    yeah hard to calibrate the SVS by ear...you could go by how much the picures rattle on the wall :D
  • PolkThug
    PolkThug Posts: 7,532
    My L/R/Center are all at +7. I think 62 on the Onkyo is my reference level at 75db.
  • thehalo8
    thehalo8 Posts: 127
    I have the older model (696) of your Onkyo. I don’t think I have ever watched a movie over 48 on my receiver. It is already loud enough to make my ears bleed at that volume. You must have a rather large room to be hitting 62 on the volume!!!
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk TC60i's
    Sub: Polk PSW505
    Receiver: Onkyo TX-DS696
    TV: Samsung HLS 5687W 56"
    DVD: Sony DVP S5300
    Protection: Monster HTS 3600
    Backup Battery: Belkin AP3080010
