Onkyo 701 Owners
Pauly
Got my new onkyo in and am pleased thus far...only had about 5 min play time and havent had chance to really play with but was wondering if anyone has a similar system than mine that has it calibrated. I can calibrate by my ear to my liking but was wondering what anyone else has theres set at until i get a spl to it. I left L,R,C,LS and RS @ 0db for now. I have 70's for fronts, 40 center and 28's rears. Any input would be greatly appreciated.
Spaz
Spaz
Life without music would♭
Post edited by Ryan_Polk on
that depends all on the size room, But as a rule, start with your center on 0 ....... you could run left and right mains at +2 or so... surrounds just play it by ear until maybe we can get together with my Spl meter.. and set that svs up also..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
so the fronts would beplaying at louder levels than the center
or is that to make up for watching HT and most of the sound coming through the center. Life without music would♭ -
Thats how my system calibrated up.. The center is usually higher then the mains,(on a tv ) maybe in front or behind the mains a bit.. rarely straight inline and that's what makes the numbers slightly different i suppose.. make em all 0 if that makes ya feel better... really play it by ear.. but the meter is the true test. you may think they all sound the same,.., but the meter is 10x more accurate i would think. specially for the sub.. no way to play that by ear at allMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
yeah hard to calibrate the SVS by ear...you could go by how much the picures rattle on the wall
My L/R/Center are all at +7. I think 62 on the Onkyo is my reference level at 75db.
I have the older model (696) of your Onkyo. I dont think I have ever watched a movie over 48 on my receiver. It is already loud enough to make my ears bleed at that volume. You must have a rather large room to be hitting 62 on the volume!!!Mains: Polk RTi70's
Center: Polk CSi40
Surrounds: Polk TC60i's
Sub: Polk PSW505
Receiver: Onkyo TX-DS696
TV: Samsung HLS 5687W 56"
DVD: Sony DVP S5300
Protection: Monster HTS 3600
Backup Battery: Belkin AP3080010
