Anybody tried these wires?
nooshinjohn
13 guage silver coated wire. I want to try these but the lack of an insulator has me a bit concerned. I was thinking of pairing them with an Odessey or Emo amp, a Kraco 8track and a set of Cervin Vegas...
Post edited by nooshinjohn on
Anticable already beat you to it, and yes, it will pass a signal, but that signal is nothing but rubbish.
Cheers,
I think you're better than that :redface:Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
May not be bad if you have the 8 track cassette adapter.Kraco 8trackTesting
Testing
Testing -
Usually I am, but tonight, my rig sits silent as a wicked thunderstorm rolls through. I won't be plugging it back in any time soon, so I thought I would try and have a bit of fun given all the wire/cable threads of late.
nooshinjohn wrote: »13 guage silver coated wire. I want to try these but the lack of an insulator has me a bit concerned. I was thinking of pairing them with an Odessey or Emo amp, a Kraco 8track and a set of Cervin Vegas...
I've got ~$1000.00 or so in my Paypal account, and can load it up more soon. What will it take to get this???
:rolleyes: -
I'm not even gonna point out the irony here.
cokewithvanilla wrote: »I'm not even gonna point out the irony here.
Yeah, but you don't run Cerwin Vegas though.:biggrin:
Do you?:eek:Testing
Testing
Testing -
John! These are exactly what you need to pair with the tube monoblocks!!! I knew there had to be something worthy of those pieces of ear candy. I figure you could cut trash bags and wrap the wire with it for an insulator
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
astounding, isn't it?design is where science and art break even. -
dcmartinpc wrote: »John! These are exactly what you need to pair with the tube monoblocks!!! I knew there had to be something worthy of those pieces of ear candy. I figure you could cut trash bags and wrap the wire with it for an insulator
Don
Duct tape will produce killer extended highs and also fleshes out a palpable acoustic envelope.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
I am mad at these because I cannot afford them. (Not sure what Joan Crawford's problem was.)
On3s&Z3r0s wrote: »I am mad at these because I cannot afford them. (Not sure what Joan Crawford's problem was.)
Why are you mad at cables you can't afford?:biggrin: -
Nvm..Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I'm just looking for a binding post to slip my banana into!!
Duct Tape? I have yet to try that. Do I use the metal tape or the plastic stuff? I fear the metal tape may bo too expensive for this project, but if it really makes that much difference, I suppose I can try it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
TOOLFORLIFEFAN wrote: »I'm just looking for a binding post to slip my banana into!!
I saw one that looked really amazing and only cost five dollars per connection. It was guaranteed you would love it long time. I think the "Sham-WOW" guy said they were "GI tested-GI approved", so they must be first rate stuff.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Duct Tape? I have yet to try that. Do I use the metal tape or the plastic stuff? I fear the metal tape may bo too expensive for this project, but if it really makes that much difference, I suppose I can try it.
Use both (and also the hunting camo variation too) in triple collagen helix braid. I can personally attest to its contribution--it's truly blows me away with a dry slam and such emotional bass extension.polkaudio Monitor 5 Series II
I heard that using both can be dangerous if not done correctly. Is there a technique you use to minimize the risk of crossing the streams? I remember Dr. Venkman saying that crossing the streams could even be fatal.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Mr. Jekyll respectfully disagrees. Using anything less than #13 AWG coat hangers and a duct tape triple collagen helix braid will be insufficient for a system of that magnitude.polkaudio Monitor 5 Series II
Are those available in a hyper-litz topology?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
What does Mr. Hyde have to say on the subject? A Google search indicates that they seem to be of two minds on the subject.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Mr. Hyde prefers Bose; we don't listen to him.polkaudio Monitor 5 Series II
nooshinjohn wrote: »13 guage silver coated wire. I want to try these but the lack of an insulator has me a bit concerned..
Tool dip my friend it's the best in this case, But i'd go one step further and also run them through PEX tubing for that "air insulator" effect and no banana plugs it would just muddy the sound unless you can find pure bright heavy brass:cool: -
You realize those have to be conditioned with di-lithium power for 100 hrs before they will sound good.
I'm old school, so I actually prefer the steel ones with the gold varnish.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Cable burn in is a total myth. Even Geordi LaForge says so:rolleyes:
.... The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Cheers,
Russ
Felt the same about those... Rubbish.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
