Car trouble
  • JimKellyfan
    JimKellyfan Posts: 696
    edited April 2011
    module is a cheap chance, and especially if it is OE.
    remember to put the heat sink compound on the backside.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    If you have a distributor, it will be there or you will see a space for where it could go.
    They eventually moved them away from the heat and on the fire wall.
    Some can be even just behind the fire wall too with only the plug visible.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    Let me know how you make out.
    And if you need any further assistance.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited April 2011
    I have the repair manual I can locate it very easily.
    More expensive than 60 bucks
    http://c2c.activant.com/ctoc/index.jsp?ID=bAi1oFiopEU5_Oy9_CUdHM2FGVBoFdSEMUnQf
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • sucks2beme
    sucks2beme Posts: 5,683
    edited April 2011
    Just because the dash light isn't lit anymore doesn't mean there isn't
    a stored code.
  • bigaudiofanatic
    edited April 2011
    I will try that.
    Because they can NOT pull the code if the light is not on. I tried to get it today when I picked up my part. The light was not on and the code puller did not get anything.
    sucks2beme wrote: »
    a stored code.
    Already tried to get a code there is none stored.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • THEJERMON
    THEJERMON Posts: 96
    edited April 2011
    I'm going with a bad spark plug wire. (I'm no mechanic but sounds like a problem I had with a ride and the spark plug wire was arcing from time to time.)
  • JimKellyfan
    edited April 2011
    good call on the wire
    if they are oe and especially if they have any white spots, could be an arcing spot
    wires will typically break up under a load, but typically not an intermittent issue and typically will leave a stored code
    on the older model Fords, there are at least two testing modes, KOER and KOEO (key on engine running and off)
    More than 60, I would shop around, too, should be lifetime part and one time purchase like spark plug wires, but, as I said, it has been awhile since I last bought one
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    wOw, 73.99 for an external module at AZ, they did go up. There are two engine types, turbo and not, and also there are two distributor types as well, internal and external modules. which vehicle do you have (turbo or not) and which set up (internal or external). I ask, as there would be testing we can do first, to confirm. But, would need to know which first.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • bigaudiofanatic
    edited April 2011
    Non turbo and I think external I will have to check when I get home tonight.
    You can fallow the project here http://www.polkaudio.com/forums/showthread.php?t=105559
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited April 2011
    Ok so after adding to the list of things.
    Distributor cap and rotor
    Spark plug wires
    I am still having the issue.
    Seems as though it is happening less now however I noticed that when I start driving the car "cold" it is fine. Than after about a half hour of driving it starts acting up. However as I said not all the time.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2011
    Does the car have an MAF sensor?
    EDIT: it does. I'd check that.
  • JimKellyfan
    edited May 2011
    again, another good call on checking the MAF
    I remember on some of the Mazda's and Ford's, if they didn't run, or had issue running, simply unplug and see how they ran like that.
    That determined what, on those mid to late 90's models anyway.
    So, how did it work out ?
    Get it figured out yet ?
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
