Car trouble
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited May 2011 in The Clubhouse
Need some help guys.
My 1994 mercury capri has decided it likes to mess with me. Car has 114k on it.
What has been done?
Fuel filter
spark plugs
injection cleaner
radiator flush
oil change
What is going on?
I could be at idel or cruising or accelerating. At any random time my car will jerk back as if miss fired or something else and the check engine light will come on. However the check engine light no sooner comes on than goes out. Once in a while it will stay on but the car will be running fine during that time which is usually like 10 seconds or so.
Any ideas what to check, replace?
I have checked the charge pack for the spark and dis cap seems to be almost new.
__________________
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2011
    Is 1994 too old to have an OBD port where you can read WHY the check engine light is coming on? Seems like that's the first step you should take if so.
  • quadzilla
    quadzilla Posts: 1,543
    edited April 2011
    Even if the check engine light goes out, you can get the error code(s) from the computer. Just take it to a mechanic, or go to your auto parts store. Either can pull the code(s) from the computer to help you figure out what's happening.
    Although a little googling indicated that one guy who had a similar problem and replaced pretty much the same stuff ended up finding out he had a bad ignition switch.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • bigaudiofanatic
    edited April 2011
    The light will not stay on long enough to get a code and yes it has one. Unless I am missing something, I thought they could only read a code if the light was on.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited April 2011
    quadzilla wrote: »
    Thank you for clarifying that. I have google with things like :mercury capri flickering check engine light or mercury capri jerking.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bobman1235
    edited April 2011
    Modern cars you can get the code whether the light is on or off. '94 is... not quite modern :)
  • quadzilla
    edited April 2011
    94 is new enough that the computer will store the fault code for about 20 starts.
    Arm: Rega 300
  • kawizx9r
    kawizx9r Posts: 5,150
    edited April 2011
    Did you replace the spark plug wires as well?
    Is the coil ok?
    Compression test?
    Also, pull out and inspect your plugs. Make sure the gap is still the same as well.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited April 2011
    quadzilla wrote: »
    I don't know about that. I have a 98' Mazda that has the check engine light come on occasionally. If the lights on, I can read the codes, when it goes out none show up at all.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
    Fuel pump?
  • headrott
    headrott Posts: 5,496
    edited April 2011
    Does the car turn over but not start every once in a while? Especially after turning the ignition switch off and then trying to start the car again soon after shutting it off? Also, if it does this, does the check engine light come on when this (above) occurs and then if you leave the ignition in the "on" but not try to actually start the car until after the check engine light goes off? Or does the check engine light only come on while driving? Or both? I had a similar problem with the symptoms I described above on my Honda CRX and it was a bad ignition switch. As quadzilla explained, take it to a mechanic or to an auto parts store and they should be able to get the error code stored in the computer after the check engine light comes on. It is stored in the computer even after the check engine light turns off, so it does not have to be on when the mechanic or auto parts store guy tries to read the code. Hope this helps.
    Greg
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2011
    post #11 by SOONU111 reported as spam
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • bigaudiofanatic
    edited April 2011
    kawizx9r wrote: »
    Is the coil ok?
    Compression test?
    No just the spark plugs as the wires and dis cap were in good condition.
    headrott wrote: »
    Greg
    No car starts right up first try. I have tried jiggling the keys when driving to see if anything happens nothing. So it is further away like ignition system I am thinking.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2011
    Hmm.... Not knowing this car but... If this car as a MAF sensor try cleaning it. Or my thinking a dirty / bad TPS.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    heiney9 Posts: 25,440
    edited April 2011
    OBD II cars store information..............1994 is too early for OBD II computers. OBD II stands for On Board Diagnostics.
    OBD I cars usually don't store the info, or if they do it's for a short time, IIRC. Maybe John will chime in.
  • nadams
    nadams Posts: 5,877
    edited April 2011
    Strange that the check engine light would come on immediately when the problem occurs, and then go back out immediately. Usually, the computer monitors a misfire condition for a little while before setting the misfire code. Then, if you resolve the misfire, it will clear itself after some smooth driving.
    Therefore, I'd also lean towards an ignition switch (with the limited information we have). When the engine stops running, the check engine light will immediately come on because the key is on but no firing. As soon as the firing resumes, there's no longer a "check engine" condition.
    But then, I'm no expert... and I didn't even stay at a Holiday Inn Express last night.
    Edit- Just thought of something.... it could also be a faulty sensor telling the engine computer that the engine is no longer turning over (which would kill spark to the engine completely). Cam/Crank position sensor failing?
    Ludicrous gibs!
  • quadzilla
    edited April 2011
    WilliamM2 wrote: »
    Interesting. My 93 Ford stores it, and my mechanic told me that most cars after about 90 will.
    Arm: Rega 300
    edited April 2011
    quadzilla wrote: »
    Depends on manufacturer and which computer type they use.
    On know for most Volkswagens OBD II wasn't available until 1995 or 1996.
  • sucks2beme
    sucks2beme Posts: 5,684
    edited April 2011
    OBDI is a bit more crude.
    http://www.extreme-check-engine-light-codes.com/Ford%20OBD1%20Decoder.htm
    This is a way to read them. Other than that, do a general look around for any
    loose or corroded connections.
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2011
    heiney9 wrote: »
    VW OBDII was introduced late 1995.
    I would see if you can get a code off the car. I would guess that you are feeling a timing problem. Had something similar in a Jimmy. Ended up being the Distributor cap and or wires.
    Just cause wires look OK doesn't mean they aren't getting brittle or corroded.
  • bigaudiofanatic
    edited April 2011
    nadams wrote: »
    That is the thing though, the car is still running just jerks and once in a while the light will stay on for about 10 seconds or more and the car will be driving fine during that time. So I can not see it being the ignition switch.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • bigaudiofanatic
    edited April 2011
    Ordered a new ignition coil today and will install it tonight see if that helps.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • sucks2beme
    edited April 2011
    If you haven't pulled the code, why not?
    It may be meaningless, or it might pinpoint the problem.
    Or throw a bunch of parts at it and hope for the best.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited April 2011
    Ignition modules are known for issues on the old Fords.
    Some are mounted on the distributor and some on the firewall.
    There is a special grease that goes on the backside as well, a heat sink white grease.
    Comes with the part.
    If it is winter time, and they are failing, you are in NJ so maybe cold still, I put snow on the module, as they usually act up warm, but can really act up anytime.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    should look similar to this and cost 30 - 60, it has been awhile since I owned a Ford.
    No offense.
    https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=MPETP57SB_0167709061
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    If the module is OE (original equipment), just change it.
    It is overdue anyway.
    Hope this helps.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • bigaudiofanatic
    edited April 2011
    No offense.
    I will try that.
    The coil did not seem to fix the problem. Once again car ran fine for almost a half hour than acted up for about 5 seconds than was fine again on the way home.
    sucks2beme wrote: »
    Because they can NOT pull the code if the light is not on. I tried to get it today when I picked up my part. The light was not on and the code puller did not get anything.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • JimKellyfan
    edited April 2011
    They have a scan tool that goes on sale every now and then made from Innova / Equus. I have the Craftsman branded version that does OBD I and OBD II, it is on sale for 299, but occasionally goes for 250 or I got mine for 199.99. Online cheaper yet.
    Here is a link:
    http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=innova+equus#q=innova+equus&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=m0mmTZevHdOftweMmbiFAQ&ved=0CFEQrQQ&biw=1280&bih=899&bav=on.2,or.r_gc.r_pw.&fp=e96376757cabdab1
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    Yeah those modules are definitely known for intermittent problems. Is yours OE ?
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • JimKellyfan
    edited April 2011
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
  • bigaudiofanatic
    edited April 2011
    Probably is
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
