What small center can i pair with RTi A5's
Enze6997
Enze6997 Posts: 6
edited April 2011 in Speakers
Just recieved my Rtia5's and csia4. Love the build quality. Unfortunately, the center just wont work for my setup. Not buying a new cabinet, tv id a huge samsung 58 inch plasma so i dont want to put anything above it. What is the smallest center (for a 3.1 setup) i can get that will match closely to the CSi A4? This sucks but the wife wont go for any other big speakers. Driving the speakers with the harmon avr 1600, and DSW pro 440wi for the sub. Help a brother out! :frown: i think i can do 4.5 inch high and up to 8 inches deep.
  • packetjones
    packetjones Posts: 1,059
    edited March 2011
    a 4.5 inch tall center will be hard to find. I would say of the CSiA4 doesn't fit then I would just go without a center.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Enze6997
    Enze6997 Posts: 6
    edited March 2011
    I know the blackstone TL3 works in a set but would it pass?
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2011
    I bought a TV2 riser. I had the same problem. My tv stand looks more like a coffee table. It has 2 dwars and one shelf. The TV2 riser is just a 8in tall shelf / riser that will allow you to put the center channel under the tv. It is made up of hard wood so it feels pretty solid. They claim that it is rated for tv's up to 120lbs. It is held together by those cam bolts. You know those steel pins that thread in to wood. Then they have the big disks that do a 1/s turn and grab the head of the steel pins.
    I also used some wood glue and 4 screws to help hold it together. It was solid with just the cam bolts but I wanted to over engineer it. There is no way it is coming appart now.
    I made a post about it in the club house. I need to update it with some pics.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Enze6997
    Enze6997 Posts: 6
    edited March 2011
    Wish I could do that... The TV stand is pretty high, up is not an option. Maybe UNDER the stand!? Might not fit though and would block some of the loudspeaker. Rats!
  • jbooker82
    edited March 2011
    You can turn the csi a4 upside down to point the speaker up at you. Or use some L brackets to hang it on the wall above the tv.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • djperez81
    djperez81 Posts: 388
    edited March 2011
    Enze6997 wrote: »
    Ahh yes i feel your pain Enze about the wife situation, i suffer with the same problem, i started of with a HTIB setup and slowly convinved her to let me upgrade. Now i have 2 setups and some equipment in the closet:biggrin:. But the center is a crucial part of you HT, if can you post some pics of what your setup looks like maybe someone can help you out with your problem. But once she hears that csi a4 in action she wont complain. Good luck
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • alanmushnick
    alanmushnick Posts: 6
    edited March 2011
    I am also looking for a smaller center to match my RTiA1 bookshelf speakers. Would the TL3 center be ok? I don't like the looks of the monster CSiA4.
  • anilksharma
    anilksharma Posts: 34
    edited March 2011
    alanmushnick/Enze6997, so finally what are you deciding for center? I am in similar situation and wondering if TL2 center might fit with RtiA1/A3.
  • Enze6997
    Enze6997 Posts: 6
    edited April 2011
    I got the TL3 and it is perfect.
  • anilksharma
    edited April 2011
    Perfect to fit in the space or do you think it's doing its job perfect as a center speaker?
