F/X Wireless Speakers / Soundbar NOT Recommended with Audyssey
deadlock2004
deadlock2004 Posts: 12
edited April 2011 in Speakers
Hi,
I'm planning on getting an F/X Wireless surround speakers. They will be hooked up on my Denon 1911. The online manual states that it recommends NOT using any automated calibration system (in my case Audyssey).
Can anyone confirm the sound quality of these F/X wireless speakers or any Surroundbar calibrated with Audyssey? Some brands state that their soundbars work well with the audyssey.
Post edited by deadlock2004 on
  • mystik610
    mystik610 Posts: 699
    edited April 2011
    Hi,
    Soundbars do all sorts of funky things to the phasing and equalization of speakers from a single fixed point to emulate true surround sound effects with sounds radiating from different parts of the room. They more or less create auditory illusions that trick your brain into perceiving a sense of directionality and depth.....the same way stereoscopic 3D video creates optical illusions to trick your brain into perceiving a greater sense of depth.
    Systems like audyssey measure the actual frequency response (actual movement of soundwaves) from various parts of the room. The audyssey microphone won't likely be tricked by the manipulation of phasing and equalization the same way a human ear and nervous system would. I'm not exactly sure how audyssey would respond to this, but I'd image that it wouldn't produce the desired effects.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    Does anyone have any experience with the FX wireless, I have been thinking about adding one to my bedroom system, would love some input from anyone using one,. Thanks in advance........................
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • jbooker82
    jbooker82 Posts: 1,627
    edited April 2011
    mystik610 wrote: »
    Soundbars do all sorts of funky things to the phasing and equalization of speakers from a single fixed point to emulate true surround sound effects with sounds radiating from different parts of the room. They more or less create auditory illusions that trick your brain into perceiving a sense of directionality and depthequalization the same way a human ear and nervous system would.
    To bad you couldnt turn the processing off and just use it as a single amplified speaker. That would make a great additon to a 5.1 to up grade to a 6.1 surround system.
    Use it as a center back channel.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2011
    There was a day when you just used a handheld meter to calibrate your HT. Just because it's manual doesn't make it un-useable.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2011
    I would imagine that most auto-setup methods would work fine so long as they're just level-matching (or doing minimal EQ like Yamaha's YPAO). However, Audyssey in particular alters things in the time domain, which can cause issues with the methods soundbars use to create the surround effect. I would guess that if it changed things too much, it would have a very negative effect on the sound of things placed in the surrounds. Audyssey also strives to eliminate unwanted reflections by tapering off the highest frequencies a bit, and since soundbars are designed to bounce sound off the side walls to simulate having speakers placed there, this would minimize their effectiveness.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    treitz3 Posts: 20,122
    edited April 2011
    Audyssey is over rated anyway. At least in my opinion. The F/X is a treat your ears will love.
  • kuntasensei
    edited April 2011
    I love Audyssey when it's properly done... but there are too many people not using tripods or mic stands and not following the basic rules of calibration, and then they wonder why they get such crappy sound. On my 9.1 setup, it does an excellent job of creating a very cohesive soundfield.
    But yeah, it really shouldn't be used unless you have a full setup, not any kind of speaker that relies on psychoacoustics or reflections.
    Equipment list:
    Emotiva XPA-3 amp
  • DMara
    DMara Posts: 1,434
    edited April 2011
    davidgale wrote: »
    I haven't use any Audyssey speakers but i am using JVC portable speakers for my ipod SP-A130B. They are very small in size but they have great sound quality. Try this
    lol :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
