Pioneer SC35 Arrives Thursday!!!
WGDB
WGDB Posts: 162
edited April 2011 in Electronics
I'm replacing a Sony STRGD 920 AVR, this Thursday - Question for the seasoned "rabbit Hole" folks. Rigged to Polk Monitor 60's up front, Monitor 40's back, PSW 125 and CSA4 center, are they ready to handle this much continuous power? Am I going to need to upgrade my speakers sooner..... or later?
Pioneer Elite SC-35, Polk RTA (Real Time Array) 12's,
Polk Monitor 40 surrounds, Polk CSiA4 Center,
Polk PSW125, Sharp LC-46D62U,
Panasonic DMP-BD85, Harmony One,
iMac streaming an Apple TVII, or Squeezebox Touch
Bedroom Rig~Sony STRDG-920, Polk Monitor 60 fronts, Polk RM6750 Satellites and Sub, Panasonic DMP-BD85
Rabbit Hole Rig~Yamaha CA1010, Yamaha CT1010, Polk SDA 2A's, Teac A1500 R2R
Post edited by WGDB on
  • B Run
    B Run Posts: 1,888
    edited April 2011
    Your speakers will be fine as long as you don't play it at ear bleeding levels. Once you hear it you're going to want to upgrade the rest of your system too haha. Good luck and congrats, that's a serious AVR.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
    Welcome to the "ICE Club" , and congrats what is a fine AVR. I have the 1st model (SC-07) and love it. Enjoy. Sub will probably be on your short list.
  • mantis
    mantis Posts: 17,561
    edited April 2011
    Sherardp wrote: »
    Ditto! Shortly followed by wanting better speakers , you now have the ability to upgrade pretty high up the food chain.
    Dan
    edited April 2011
    Congrats, that new SC is going to destroy your old Sony, not by alittle bit either. Take your time,set it up right. Use the auto calibration, make sure the mic is set at ear level in your listening position. You can always tweek everything after. Happy listening.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited April 2011
    Congrats on the SC. I went from an HK to the SC-37 and it's a world of difference. Not only is it a bit more powerful (gained only about 40 wpc real-life), but the processing is leaps and bounds above anything I've heard (which isn't much honestly)
    This is where you do a facepalm, say "Doh!" and wish you would have gotten the 70's though. But I do agree, the sub is going to be your weak point at this time.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    txcoastal1 Posts: 13,519
    edited April 2011
    Awesome it will upgrade your DVD and play your speakers to the best that a AVR $1000-$1500 can do and out do others with features ....and yes you are ready upgraditis...enjoy
  • mtdewcowboy
    mtdewcowboy Posts: 15
    edited April 2011
    Congrates
    That is my next buy a sc something
    Pioneer 515 vsx
    Polk Monitor 50's Fronts
    Polk Monitor 30's Surrounds
    Polk CS10 Center
    Yamaha yst-sw216 Sub
  • WGDB
    WGDB Posts: 162
    edited April 2011
    Thanks ya'll. I will be taking the install slowly as I will need to run an ethernet through the attic to the wall from my router. I will also need to modify my the back of my entertainment cabinet for easy hookups and better ventilation. Although, I've read and been told ICE runs very cool.
  • WGDB
    WGDB Posts: 162
    edited April 2011
    Glowrdr wrote: »
    I did just that - and the sad part is, when I bought the 60's, the Monitor 70's were just a few dollars more during the same New Egg sale.
  • WGDB
    WGDB Posts: 162
    edited April 2011
    tonyb wrote: »
    Appreciate the input. Slow is good...
  • WGDB
    WGDB Posts: 162
    edited April 2011
    txcoastal1 wrote: »
    Thanks, Panasonic BD 85 looks good already - can't wait to see the improvement
  • WGDB
    WGDB Posts: 162
    edited April 2011
    Tech question: I want to make sure my SqueezeBox uses the Burr Brown DAC in the SC 35, not the Squeeze Box DAC. The SqueezeBox has both 2 channel RCA's and/or SPDIF. If I hook the SqueezeBox output as SPDIF, will the SC35 take over the digital analog conversion (DAC)? Or should I send the signal through the 2 channel in some sort of direct mode?
  • SRTer
    SRTer Posts: 372
    edited April 2011
    WGDB wrote: »
    Yes, the SC-35 will decode the digital information with its own DAC.
    Also, welcome to the "ICE club" as stated before.
    I love the SC-35 and have put it to the teat with my setup.
    http://www.polkaudio.com/forums/showthread.php?t=117648
    I'm more than sure you will work those Monitors and PSW sub to death. The Monitors nice but are not ready for what you?re going to put to them.
    Specifically your Monitor 40?s are rated 20-125 watts, and the SC-35 will put at least 135 watts to each of your speakers in 5.1 channel. Home Theater .Com tested a SC-37 with the same power section and the bench test said.
    HT Labs Measures
    Five channels driven continuously into 8-ohm loads:
    0.1% distortion at 135.7 watts
    1% distortion at 171.9 watts
    http://www.hometheater.com/content/pioneer-elite-sc-37-av-receiver-ht-labs-measures
    Are you ready for new speakers? If not, I would keep the volume below -10dB, which is where my RTi A speakers start to really wake up.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • BWilberg266
    BWilberg266 Posts: 191
    edited April 2011
    Very nice purchase.
    I guess the thing that throws me off is the speakers that people often connect to the high end equipment. Maybe it's just a "gotta start somewhere" thing.
    I've got about $2000 worth of speakers/sub running on my Denon 1910 which will be heading out the door in favor of an SC or a 1120 w/ separate amps setup in a couple of months. But when I see $1000 of speakers with a $2000 receiver I'm just thrown.
    Now I am definitely always in favor of more power. But as SRTer said, it's going to be more than those speakers can handle.
    Can anyone chime in on this? Maybe I'm missing something here.
    (All of the above is written in sincerity not sarcasm, I really do want to know if I am missing something here. Always trying to learn :smile: )
    Main Setup
    Fronts - Energy RC-50's
    Center - Energy RC-LCR
    Rear - Energy RC-R's
    Subs - Gone...
    AVR - Pioneer SC-37
    Blu-Ray - Sony BDP-S360
    TV - Vizio E550I-B2
    Media Server - Mac Mini
  • WGDB
    WGDB Posts: 162
    edited April 2011
    Very nice purchase.
    Absolutely get what your saying BWilberg266 - To me it's kinda like building a hot rod starting with the engine first. That, and I'm trying to avoid having to buy a new AVR over the next 5 to 7 years. Speakers will be next on the list and coinage was there for me to start right at the heart of my dream system.
  • WGDB
    WGDB Posts: 162
    edited April 2011
    SRTer wrote: »
    HT Labs Measures
    I just popped in and looked at your setup. Sweet! I'm leaning directly towards the RTI series as well.
  • SRTer
    SRTer Posts: 372
    edited April 2011
    WGDB wrote: »
    Thanks, my setup has me in a postion where I don't feel I have to do anymore. However, I do want a dedicated Rotel amp for the RTi A9's.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  • WGDB
    WGDB Posts: 162
    edited April 2011
    SRTer, How would you set the Rotel up to dedicate it to the RTI A9's?
  • SRTer
    SRTer Posts: 372
    edited April 2011
    WGDB wrote: »
    Use the RCA audio out on the SC-35 for the input on the Rotel amp.
    Do a 2 channel Rotel amp.
    Some say to do a 3 channel but I don't need that. The Pioneer Elite SC-35 will have more than enough power to taker car of the remaining speakers.
    Once the gain is set on the Rotel amp, I would run the automatic calibration on the SC-35. The SC-35 will set the trim or gain (which ever you use) for a speakers to sound right in it's program.
    Therefore, the RTi A9's will not be to loud. It should be pefect then.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  • mantis
    edited April 2011
    SRTer wrote: »
    Why? The SC-35 will drive them fully. I see other things maybe in your system to further your enjoyment.
    Dan
  • SRTer
    SRTer Posts: 372
    edited April 2011
    mantis wrote: »
    Well, I just want it. There is nothing else i feel that I'm lacking. I may get another sub down the road, but it's really not needed for my current room plus I have plenty woofers making bass. I have ten 7 inch woofers.
    The RTi A9's are rated for 500 watts. I would love to see 250-300 watt on them just to make me happy. There will be much more than the 135 watts the SC-35 makes in 5 channel mode.
    That would leave plenty power left over from the SC-35 to the center and rears RTi A7's.
    What do you see that will further my enjoyment. Maybe a projector? What?:confused:
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  • WGDB
    WGDB Posts: 162
    edited April 2011
    SRTer wrote: »
    I call it MAX HEADROOM- that's a fact.... But I'm Okay with it.
  • BWilberg266
    edited April 2011
    WGDB wrote: »
    I see where you're coming from. I'm wishing I would have upgraded to something better than the 1910 after my old Yamaha AVR. Pre-outs should have been a must, but now I guess I will get a solid base with HDMI 1.4 which I would not have been able to do before.
    Dang technology and it's ever changing ways...
    Main Setup
    Subs - Gone...
    AVR - Pioneer SC-37
    TV - Vizio E550I-B2
  • SRTer
    SRTer Posts: 372
    edited April 2011
    Yeah HDMI 1.4, 3D and iPhone 4 apps I felt was a must for use with my new AVR. I had not even had my last reciever (Pioneer Elite VSX-23) a year before I figured I had messed up.
    Plus, I wanted more speakers with demanding power levels.
    Upgrade-I-tis is a mother*%#@er. :mad:
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    edited April 2011
    Technology 'sucks' and it's also 'great'. It's kind of like that obscure object of desire--two women; the seductress and the ****. Unfortunately they are the two who are really ONE when you're in the market for a new upgrade.
    As for me. I upgrade on my 'own' timetable so I'm not always pursuing the elusive Bunuelian 'object'.
    All this aside. It's Thursday, Thursday....it's Thursday, Thursday; I don't mean Friday, Friday....lol
    Hey, did your Pioneer arrive yet?
    cnh
    F1nut Posts: 52,002
    edited April 2011
    That is simply not true. You are much more likely to damage your speakers with too little power verses too much. The Monitor 40's will be perfectly fine with the SC-35.
  • WGDB
    WGDB Posts: 162
    edited April 2011
    Not arrived yet - it shows "out for delivery"
  • WGDB
    WGDB Posts: 162
    edited April 2011
    SC - 35's just arrived double boxed and in great shape. Feeling a little like Christmas morning as a child some 45 years ago.
  • Grimster74
    Grimster74 Posts: 2,577
    edited April 2011
    Not to steal your thunder but just sharing, expecting my SC-37 sometime next week and will be moving my SC-07 to the upstairs rig. If you don't mind me asking, where did you purchase your SC-35 from? Oh yeah, welcome to the ICE club!
  • BWilberg266
    edited April 2011
    I do not mean to imply that you cannot power a lesser speaker with an amp well above it's power rating, but rather that you do run the risk of blowing the speaker should you really start cranking it up.
    Yes you can damage speaker with too little power, but typically that only happens when you have a receiver or power source that provides an amount of power that is not significantly lower than the maximum wattage handling of the speaker. If the power supplied is say 3 to 4 times less than the maximum power handling of a speaker it may sound like crap when you crank it up to the max, but there is a very low likelihood that the speaker will have much, if any, damage. There will be alot of distortion, but a low likelihood of damage to the speaker.
    When you approach a power level that is much closer to the maximum power handling of a speaker and introduce high levels of distortion that is where you have a problem.
    Think of it this way. Kicking a soccer ball randomly around a gym is not going to be a problem because that larger space has the ability to accommodate large erratic dispersions of energy. Kicking a soccer ball erratically around your living room on the other hand will present some problems, more than likely there will be damage. In both scenarios there is the same amount of random bouncing coming from the ball, but in one instance the room is suited to contain a larger release of energy and in the other it simply cannot contain that same amount of uncontrolled action.
    So yes, there is a possibility of damaging a speaker with a low powered amp, but is not in the way that everyone likes to throw that phrase around.
    Crank a speaker up on an underwhelmingly powered AVR...not likely that it's going to be a problem. (besides sounding crappy due to high levels of distortion) Crank a speaker up on an overwhelming supply of power with a speaker that can't handle the amount of power you are giving it, and you'll get a blown speaker.
    Main Setup
    Subs - Gone...
    AVR - Pioneer SC-37
    TV - Vizio E550I-B2
