Audio Quest Rocket 33 speaker cable question.
I was wonding if anybody has tried the Audio Quest Rocket 33 speaker cables. Specifically the bi-wired ones terminated in banana plugs. I have seen / herd of people getting rid of the jumper strap and using a pice of speaker wire. Why not use a clable that has the "jumper" built in?
My current setup is a Onkyo 808 avr and RTI A7 speakers. I currently have them hooked up normally with the factory jumpers, and 12 gauge monster cable.
Would I see an improvement and what other speaker cables would you suggest?
thanks for your time
josh
josh
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
Rear: FXI A4
You might want to look at Kimber Kable 12tc.
Hey jbooker82
Kimber Kable 12tc cost 700 dollars for a 10' pair , you could buy another pair of speakers. Audioquest is half that. For me Blue Jean speaker wire.
Check out their prices.Equipment
Panasonic TC-P54S2 Plasma
Scientific Atlanta DVR
ONKYO TX-SR705 AVR Pre/Pro
Outlaw 7125 7 CH Power Amplifier
Toshiba A2 HD-DVd
Panasonic BD-30
Harmony 550 remote control
LSi9 ( Mains )
LSiC ( Center )
PSB Ambient 2 Dipoles
SVS 20-39 PCI Subwoofer -
you'l hear a variety of opinions from cables make no changes to they make huge changes.
if your going to go down the cable road to find out yourself, start cheap. Kimber Cable = fail.....at least to start (or for me, hell will have a raging snowball fight before I pay 700 for cables)
don't hesitate to go used on cables either. check audiogon or ebay.....don;t break the bank though. don;t even think of breaking 100 to start (and even thats alot)
the monster 12 gage is very good cable, it;s jut the company and there practices i hate. not to mention I hav had there 12 and 14 guage wire oxidize faster than other cable I have owned.
bluejeans cable, as mentioned below, is a great cable at a great price. do a search here for diy cable and don't be afraid to go that route. seriously, If I can do it, so can you.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
So the monster cable I have now is good, just made by a company that has business practices.
I guess maybe I should hold off on the cables, and put the money twards a good amp, unless I find a some good used ones for a desent price.AVR: Onkyo Tx-NR808
Rear: FXI A4
IC: AudioQuest Black Mamba II -
Your Monster cable is fine for now. Put the money towards a good amp. If you do want to try something else, here's a good place for speaker wire on the cheap: http://www.accessories4less.com/make-a-store/category/SpeakerWirePins/Speaker-Wire-Connectors/1.htmlDisplay: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
I can definitely say that they have business practices
Certainly go for a amp before getting carried away with speaker wires because the road of wire is long and can be never ending.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
cokewithvanilla wrote: »I can definitely say that they have business practices
I ment to say bad business practices. I have just herd people on here not speak to highly of them.AVR: Onkyo Tx-NR808
Rear: FXI A4
