Audio Quest Rocket 33 speaker cable question.
jbooker82
jbooker82 Posts: 1,627
edited April 2011 in Speakers
I was wonding if anybody has tried the Audio Quest Rocket 33 speaker cables. Specifically the bi-wired ones terminated in banana plugs. I have seen / herd of people getting rid of the jumper strap and using a pice of speaker wire. Why not use a clable that has the "jumper" built in?
My current setup is a Onkyo 808 avr and RTI A7 speakers. I currently have them hooked up normally with the factory jumpers, and 12 gauge monster cable.
Would I see an improvement and what other speaker cables would you suggest?
thanks for your time
josh
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
  • stillen
    stillen Posts: 43
    edited April 2011
    You might want to look at Kimber Kable 12tc.
  • ALWALLER
    ALWALLER Posts: 40
    edited April 2011
    Hey jbooker82
    Kimber Kable 12tc cost 700 dollars for a 10' pair , you could buy another pair of speakers. Audioquest is half that. For me Blue Jean speaker wire.
    Check out their prices.
    Equipment
    Panasonic TC-P54S2 Plasma
    Scientific Atlanta DVR
    ONKYO TX-SR705 AVR Pre/Pro
    Outlaw 7125 7 CH Power Amplifier
    Toshiba A2 HD-DVd
    Panasonic BD-30
    Harmony 550 remote control
    LSi9 ( Mains )
    LSiC ( Center )
    PSB Ambient 2 Dipoles
    SVS 20-39 PCI Subwoofer
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2011
    you'l hear a variety of opinions from cables make no changes to they make huge changes.
    if your going to go down the cable road to find out yourself, start cheap. Kimber Cable = fail.....at least to start (or for me, hell will have a raging snowball fight before I pay 700 for cables)
    don't hesitate to go used on cables either. check audiogon or ebay.....don;t break the bank though. don;t even think of breaking 100 to start (and even thats alot)
    the monster 12 gage is very good cable, it;s jut the company and there practices i hate. not to mention I hav had there 12 and 14 guage wire oxidize faster than other cable I have owned.
    bluejeans cable, as mentioned below, is a great cable at a great price. do a search here for diy cable and don't be afraid to go that route. seriously, If I can do it, so can you.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • jbooker82
    edited April 2011
    So the monster cable I have now is good, just made by a company that has business practices.
    I guess maybe I should hold off on the cables, and put the money twards a good amp, unless I find a some good used ones for a desent price.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2011
    Your Monster cable is fine for now. Put the money towards a good amp. If you do want to try something else, here's a good place for speaker wire on the cheap: http://www.accessories4less.com/make-a-store/category/SpeakerWirePins/Speaker-Wire-Connectors/1.html
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited April 2011
    jbooker82 wrote: »
    I can definitely say that they have business practices :tongue:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited April 2011
    Certainly go for a amp before getting carried away with speaker wires because the road of wire is long and can be never ending.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • jbooker82
    edited April 2011
    I ment to say bad business practices. I have just herd people on here not speak to highly of them.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
