New House need suggestions for setup
TouchOfEvil
Hello, so we are buying a new house and this is going to mess up my HT setup as it currently sits.
The new house has a living room of 22ft long by 16ft wide 22x16 but it is open on the top left corner of the room about 7foot i guess into the kitchen/breakfast area which is at least the same size by looking at it.
I currently have the LSI setup w/ a velodyn spl1000 for the sub but i don't think that sub is going to be enough to fill that much space with the room open like it is.
Room also has a fireplace so totally gonna throw off the sidewall on left channel compared to right channel front.
What do you suggest i do for the sub in this room?
The other problem...master bedroom sigh. There isn't enough room with the dimensions/door placement for my rtia5's in the room. The speakers will have to be downgraded to most likely a wall speaker for fronts/rears or have the fronts on stands but very close to the sides of tv maybe a 12"-16" off the wall at most and about 5foot at most between them.
Should i sell the rtia5's and get a second pair of a1's or purchase a second set of Tannoy DC4's and use these as fronts/rears since a much smaller footprint than even the rtia1s and they are duel concentric monitors so great for nearfield or would this be a bad idea?
I know long read but i really appreciate the help!!!!
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
I'd give the sub a shot and see how it goes. If it's not enough, consider picking up a matching subwoofer, stepping up to a more powerful Velodyne, or moving to a JL Audio or DIY sub system
If you're gonna go in-wall, I'd go with Sonance. They make some pretty nice stuff. Or the LCi-RTS stuff. Personally I wouldn't go for anything less, but that's my taste. On-wall speakers would work as well. The top end of the Atrium lineup have some pretty sweet punch, or you can put A1s on some wall-mounts.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Pretty sure the sub won't be enough as i've had it in a room with like problems and it wasn't enough omph for me. A second 10 might solve the problem but also open to other sub ideas that can get it done with a single sub.
On the bedroom another set of rtis might be the way to go but i know i'm gonna be missing the rti5's going with the a1's on wall. However, i don't want to purchase an whole new setup really. Would rather stay rti or maybe add to my tannoys unless the tannoys are a bad idea for this setup. Currently they are my computer speakers but get very little use as i tend to use the headphones instead.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
bump iso more info.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
I would sell the A5's and get A3's on stands for the front...or even RTI6's if you can find a pair.
Above suggestin for the bedroom setup."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
How big are the A3's though? The amount of room is limited between door ways and i need a small foot print.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
You bought a new house without mapping out the placement of you system? What were you thinking? You really need to get your priorities in order !!!!!!If you can't hear a difference, don't waste your money.
Yeah i know i should have said no unless you can give me these dimensions lol.
Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
renowilliams wrote: »
Yeah this helps. I know the A3's are gonna be too big so it's a1's or go with the Tannoys which are a good bit smaller than the a1's. Just curious how this setup would work being they are near field speakers.Living Room Rig:D
Xbox360/PS3/WII
M.Br. setup:)
Computer Rig:
