ohm of speakers
kevinkennedy
Hi -- I have a pair of Polk Monitor Series 2 speakers built in 1991 with a MW6502 driver. I just bought a new Sherwood receiver and was told (after the purchase) that if my speakers aren't 8 ohm speakers, they will break the receiver. I've been inside and out of my speakers and can't find and reference to ohms. I'm looking for my users manual, but I thought I'd check in here to see if anyone knew the answer. Thanks.
99% percent sure they are 8 ohm. Thinking only Polk's LSi series is 4 ohm.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks!
kevinkennedy wrote: »Hi -- I have a pair of Polk Monitor Series 2 speakers built in 1991 with a MW6502 driver. I just bought a new Sherwood receiver and was told (after the purchase) that if my speakers aren't 8 ohm speakers, they will break the receiver. I've been inside and out of my speakers and can't find and reference to ohms. I'm looking for my users manual, but I thought I'd check in here to see if anyone knew the answer. Thanks.
Hey, before you hook those speaks up. Get a ohm meter and check it out. Should read 8ohms + or - .6 if it a 8 ohm speaker.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
I bet closer to 6 ohms if you back out a meter, but don't worry about that.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Thanks all for the feedback. We finally heard back from Polk, and they tell us it's 8 ohm.
On speakers like the LSi line would it work to remove the bi-wire jumpers and wore the posts in series? By that I mean have + from the receiver wired to the top red post, - from the receiver to the bottom black post, and a jumper connecting the top black to the bottom red post. Would that create an 8 ohm load?
Nope.HT SYSTEM-
