ohm of speakers
kevinkennedy
kevinkennedy Posts: 3
edited April 2011 in Speakers
Hi -- I have a pair of Polk Monitor Series 2 speakers built in 1991 with a MW6502 driver. I just bought a new Sherwood receiver and was told (after the purchase) that if my speakers aren't 8 ohm speakers, they will break the receiver. I've been inside and out of my speakers and can't find and reference to ohms. I'm looking for my users manual, but I thought I'd check in here to see if anyone knew the answer. Thanks.
Post edited by kevinkennedy on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2011
    99% percent sure they are 8 ohm. Thinking only Polk's LSi series is 4 ohm.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • kevinkennedy
    edited March 2011
  • SRTer
    SRTer Posts: 372
    edited March 2011
    Hey, before you hook those speaks up. Get a ohm meter and check it out. Should read 8ohms + or - .6 if it a 8 ohm speaker.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • disneyjoe7
    edited March 2011
    I bet closer to 6 ohms if you back out a meter, but don't worry about that. :wink:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • kevinkennedy
    edited March 2011
    Thanks all for the feedback. We finally heard back from Polk, and they tell us it's 8 ohm.
  • Slaine777
    Slaine777 Posts: 78
    edited April 2011
    On speakers like the LSi line would it work to remove the bi-wire jumpers and wore the posts in series? By that I mean have + from the receiver wired to the top red post, - from the receiver to the bottom black post, and a jumper connecting the top black to the bottom red post. Would that create an 8 ohm load?
    edited April 2011
    Slaine777 wrote: »
    Nope.
